safe nitrous setup
Old Sep 12, 2007 | 04:04 PM
muskegoil's Avatar
safe nitrous setup
i was wondering if anybody doing nitrous.how much hp gain can you expect without damaging engine.i read 50 shot should be safe but is it worth the money for that little hp gain.
Old Sep 12, 2007 | 04:08 PM
RaineMan's Avatar
50hp is not a "little" gain on an engine running ~150 to the wheels to begin with.
It should be pretty safe... but make sure you get a quality system and have someone that knows NOS install it and teach you how to use it properly...
NOS used wrongly = boom.
Old Sep 12, 2007 | 04:12 PM
nramlow2006's Avatar
word.... btw there is no safe nitrous... just not so dangerous lol.. make sure you runa wet kit
Old Sep 12, 2007 | 09:50 PM
wordsthatiwrote's Avatar
Isnt there a video on you tube entitled Cobalt nitrous explosion? Something to that effect?
Old Sep 12, 2007 | 09:57 PM
Omega_5's Avatar
http://www.youtube.com/watch?v=VYf5OIQG8XA
He did a wet 75 shot.
It blew before he even left the line. I'm guessing too much too soon.
Just install an RPM window switch and TPS switch and you should be fine.
Old Sep 12, 2007 | 10:08 PM
skymynx's Avatar
^basically he is right. i've been running it for a while now. never had a problem. just make sure you really do your homework on this. by the way a 50 shot is alot on our motors no mater which motor you have. think bout it if your a 2.0 you have 255 horse with stock plus a 50 shot thats evenlent to having 100 shot on a C5. Your gonna notice a difference. Hell I can break my tires loose in second doing 50 mph when i hit it.
Old Sep 12, 2007 | 10:57 PM
wrong his window switch failed..
Old Sep 12, 2007 | 11:29 PM
CARLOS's Avatar
i'm have a 75shot with a momentary switch, I don't trust the window switch. this way, you just spray wen ever you want, as much as you want.
Old Sep 13, 2007 | 07:16 AM
skymynx's Avatar
i personally have a push button switch. that way i can completly control it. love it by the way. hoping to possibly throw it back in and get to the track this season. by the way if your a ss/sc please dont even bother to use it in 1st gear. middle of 2nd at the very least
Old Sep 13, 2007 | 10:30 AM
Omega_5's Avatar
Giving too much too soon....
Old Sep 13, 2007 | 10:35 AM
SSBOOST's Avatar
That's the way I will have setup shortly. Only spray as much as you want to, perfect.
Old Sep 13, 2007 | 10:41 AM
RollermanDan's Avatar
Wrong again...
Issue was the switch thought it was in 2nd gear when it wasn't and started injecting nitrous into the intake half a second before launch and there were a fuel puddling issue. It's happened to another member on here as well. As soon as gas pedal was pressed, kaboom.
Nothing about too much too soon considering the 14.6 run was run on the exact same set up as the one where it blew.
Old Sep 13, 2007 | 10:50 AM
Originally Posted by RollermanDan
Wrong again...
tell em... lol
Old Sep 13, 2007 | 10:59 AM
Omega_5's Avatar
Wrong again...
Ah jeez... you guys are totally missing the point.... Once again reading > than most CSS'ers
If the window switch failed it would start injecting too much too soon, causing it to puddle in teh intake... just as you wrote right here....
And I never what caused the problem.... Just what happened
Now, how am I wrong?
Please point out where I ever said that he intentionally made it get too much?
Old Sep 13, 2007 | 11:05 AM
now your just covering your tracks lol.. j/k
i wouldnt even spray off the line unless i had a auto..
Last edited by nramlow2006; Sep 13, 2007 at 11:05 AM. Reason: Automerged Doublepost
Old Sep 13, 2007 | 11:41 AM
Omega_5's Avatar
Me either... we have enough traction problems as it is...
Old Sep 13, 2007 | 11:53 AM
skymynx's Avatar
amen to that. traction on our cars sucks beyond believe.
Old Sep 13, 2007 | 07:01 PM
Load some concrete in to the engine compartment and viola there goes your traction woes.
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Rduncanss06
Sep 27, 2015 11:17 PM
