Seeing Knock on my aeroforce gauge
Old Mar 2, 2012 | 01:48 PM
DCOBALTSS's Avatar
I dont know but its been like 2 weeks now im seeing knock retard on my gauge
usually about 3 but today it was 5...
what should i do any ideas
thanks
Old Mar 2, 2012 | 06:44 PM
boosted05ss's Avatar
thanks
what you got in ur car? if its built up a lil dial it back and look @ ur fuel trims and go from there
Old Mar 2, 2012 | 07:38 PM
nhanson's Avatar
Are you running premium? How is your maintenance? Are you tuned?
Old Mar 2, 2012 | 07:40 PM
TommyP's Avatar
AWD > FWD
ya, gonna need some details before we can help you...
Old Mar 2, 2012 | 09:45 PM
DCOBALTSS's Avatar
Yes im a 2.4 supercharged with a 2.9 pulley running 91oct winter gas.. in quebec canada
Old Mar 2, 2012 | 11:07 PM
nhanson's Avatar
So how is your maintenance? Plugs go bad quicker when boosted. Also last time you changed fuel filter?
Also could be in the tune, maybe have it scaled back some?
Old Mar 2, 2012 | 11:10 PM
TommyP's Avatar
AWD > FWD
well it could easily be winter fuel. It's most likely a tune related issue. I'm going to guess you were tuned in the summer, winter blend may not be as strong, causing you to knock a bit because you can run more timing in the summer. You really shouldn't be beating on your car when it's cold out anyways, so go easy on it, when it warms back up again, and we start seeing some summer blend, see if it goes away.
Chevycobaltss3's Avatar
(Wintergas) retune and turn timing down, and richen it up a little and tune in fuel trims.
Old Mar 2, 2012 | 11:11 PM
nhanson's Avatar
Shouldnt it be reverse effect since winter blend is more ethanol?
Old Mar 2, 2012 | 11:26 PM
Incorrect, ethanol if added to fuel condensates water which is why ethanol winter blend is **** as well. And also if say the gas is e10 and your tuned for say 91 like op, his trims will Skew, possibly enough to cause his kr...
Old Mar 2, 2012 | 11:52 PM
chood711's Avatar
I always see KR on intercepter but if I datalog with VCM then I show none.. I've seen a few posts where people see KR on their interceptor so it may be false knock if it isn't to bad.
Old Mar 3, 2012 | 08:36 PM
DCOBALTSS's Avatar
yep guys car was tuned during the summer, im pretty sure its the gas..
right now i dont really beat the car that much because i need a new clutch lol which is gonna come in may..
As for maintenance car has 55000Km, im gonna do fuel filter this summer.
Its been boosted @47000Km approx.
So ill go easy on it, install my new clutch, change the fuel filter, and prob do a retune..
What kinda of general maintenance should i do now??
thanks
Old Mar 4, 2012 | 01:32 PM
nhanson's Avatar
Computer sees knock from the sensor on the front of the block only right?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
