SS 2.4 Stock Dyno
Old Dec 22, 2008 | 09:57 PM
Matt M's Avatar
SS 2.4 Stock - Updated with Dyno Numbers
What kind of WHP numbers should an '06 2.4 put down bone stock. I'm guessing it will make 150-160 based on accelleration.
Thanks!
slowswap's Avatar
155 whp if 5 speed.
Old Dec 22, 2008 | 10:11 PM
Matt M's Avatar
Originally Posted by slowswap
155 whp if 5 speed.
It's an auto. So what are we looking at 145-150? It seems higher, but I guess it is pretty light.
Old Dec 22, 2008 | 10:16 PM
Acey's Avatar
Less than 150 for sure. In fact because of the poor gearing in the auto, a 2.2 5-speed is probably quicker.
Old Dec 23, 2008 | 12:14 AM
rockstar014's Avatar
no way!!!! i have a auto 2.4 and i pushed 152 whp
and that was when i was stock
Last edited by rockstar014; Dec 23, 2008 at 12:14 AM. Reason: Automerged Doublepost
Old Dec 23, 2008 | 12:20 AM
Acey's Avatar
Oh, you're a stunning 2 whp over 150. Go back the next day and you'd be under. The day after on a different dyno you'd be 160. Fact is... the auto sucks power.
Old Dec 23, 2008 | 12:26 AM
iLLmaTic3s's Avatar
auto tuned=different
but yeah stock 2.4 auto will be between 145-155whp...mine put down 154whp stock
5spd ive seen between 150-160 stock
Old Dec 23, 2008 | 01:39 AM
celicacobalt's Avatar
the auto isnt that bad on this car and when you tune the auto it really wakes up. i dont see a 2.2 5 speed beating a 2.4 auto if both are raced properly.
Old Dec 23, 2008 | 10:40 AM
Red07SSNA's Avatar
Originally Posted by Acey
In fact because of the poor gearing in the auto.
2.4L auto tranny 3.91:1 final drive is an excellent ratio for accelerating. You also forget that the converter is actually a plus under acceleration -- multiplies torque under acceleration because of the stator. There's more to an auto than is widely known...
Old Dec 23, 2008 | 01:40 PM
i agree with red
Old Dec 23, 2008 | 05:24 PM
iLLmaTic3s's Avatar
agreed..this is why a tune opens up the auto 2.4 real well...a tune done right..lol
Old Dec 23, 2008 | 07:59 PM
DaBuzzard's Avatar
Yep, the torque converter really does give a big boost in the low end torque delivered to the wheels....question is, can you get it hooked up? If you can, it's soooo much easier to drag an auto with consistant results...too many variables with a stick.
Sure hope hptuners gets the 08 2.4 unlocked for us soon, would like to do a few things that only a tune can do
Old Dec 23, 2008 | 08:09 PM
hey i do need to tune my car looking for a tuner
Old Dec 24, 2008 | 06:49 PM
Shibito's Avatar
HPT is unlocking the 08 2.4L this Spring from what I've heard.
Old Dec 24, 2008 | 07:09 PM
xander40's Avatar
how much do people usually charge for a tune? and where's a good place in the houston area to go?
Old Dec 24, 2008 | 07:38 PM
glen229's Avatar
the guy installing my s/c has the beta software that nobody else has to tune my 08 sport
Old Dec 24, 2008 | 07:57 PM
REDFOCZ's Avatar
I normally charge between $200-250 depending if it is an Auto or five speed, and mods
done to the car.
Old Dec 24, 2008 | 10:22 PM
Dunkinuts's Avatar
check my sig for my numbers. But a tune would really help with an auto.
Old Dec 26, 2008 | 02:09 PM
NarutoDF's Avatar
depends on the conditions. Some shops are warmer or cooler then others and eeryone knows that cooler weather is better to run in. My car runs at little shittier when its above 75 and humid. But when its about 50 outside its perfect. Im sure there are more variables then that though. As for the shifting in a auto 2.4. Can you get a shifting chip for the 2.4 like the 2.2 has? i have a 5speed but i was just wondering.
Old Dec 26, 2008 | 02:22 PM
Red07SSNA's Avatar
If you mean the B&M shift-plus...works on both the 2.2 and 2.4 autotrannies. The auto is pretty much the same -- just the final drive ratios are different...3.63:1 in the 2.2 and 3.91:1 in the 2.4
Old Dec 26, 2008 | 02:29 PM
iLLmaTic3s's Avatar
the shift kits are good for the 2.2 cuz not many companies have tuning available..but the tune on the 2.4 opens the whole care up..def get a lot of gains on a good tune.
Old Dec 26, 2008 | 06:45 PM
Matt M's Avatar
Got her on the dyno today, and you guys were right on. Bone stock and running 87 octane, it put down a couple 146whp pulls and a 148whp pull. With a quick PCM mod to run closer to 13:1 AFR, and 1 degree added timing, it put down 150. The real improvement was in the average HP gain of 6whp and nearly 8 ft lbs of torque gained at 4800 RPM. With another degree of timing added it already had KR. and hit 150whp again. I'm thinking some exhaust mods would allow a more aggressive tune. Otherwise, It's going to need 89 octane or higher to get much more out of it without any mods.
We will keep you updated with our progress.
Old Dec 26, 2008 | 06:48 PM
steddy2112's Avatar
Run 91 or better...you can turn the timing up a little.
Old Dec 26, 2008 | 06:58 PM
olivecj's Avatar
Thanks for giving the dyno results. I got a g5 gt and its a auto. I only have a k/n typhoon intake for mods so with that i should be atleast 160 whp.
Old Dec 26, 2008 | 07:00 PM
G5GT2007's Avatar
my stock number are in my sig. as of now last time i had it dynoed it was 170whp and 168wtrq
