Supercharged G5 Dyno results an video
talk abotu freakin awesome....i was begining to plan a custom turbo setup but i may just have to scratch that and go with this....especially with the potential this setup has...or looks to have
i dont see why not....same everything....and i believe a bit bigger engine bay....
an overall lack of detail make this seema bit fishy....is it intercooled?...what did you use for tuning?....why not uprgrade the injectors to 42lb?...there are more but those should get you started
probably all the stuff off an ss/sc manifold, alternator, tensioner, all pulley's injectors, you could probably get the gm cavi s/c pulley for it (only pullied for 10 psi) and then tuning for a fake map sensor setup (like the cavi tuning, buit more complicated) This would by no means be an easy setup, but better than going custom turbo since most if not all parts should bolt right up to the 2.4 block
