Supercharged G5 Dyno results an video
Also highly recommended that you have a wideband installed on your car, preferably one you can log with, I recommend the LC1.
so basically...byt he time you add everything up itl pretty much round out to damn close to the amount of money the hahn kit is costing and your making a little be more power with the hahn kit....but its still nice to have diff. boosting options
hahn kit cost an extra 1,000 plus install.
i believe the hahn kit was making 240 ish hp/tq....install isnt that bad...id do that myself...kits is just 3100 for everything...including the tune....and if you dont have anyone near by then you have to buy hptuners plus a liscence which is roughly another 600-700...so thatd put you right around the price of the hahn kit..now lets say you could find the parts for the kit cheeper...and have someone around with hptuners...then youd be set
Price for a kit with all new parts:
alternator $351.98
Eaton M62 $1087
lower intake manifold $532
Cobra Heat Exchanger $200
Bosch IC Pump $80
fitting and piping $60
GM stage 2 belt $40
ribbed idler $30
intercooler surge tank $65
intake you can use the GMPP for the 2.4L or see below
parts we will fabricate:
additional idler with bracket $150
IC pump bracket $100
CAI for M62 $250
So a grand total of $2945.98US with all new parts
Tuning will be an extra $250US
alternator $351.98
Eaton M62 $1087
Bosch IC Pump $80
GM stage 2 belt $40
ribbed idler $30
CAI for M62 $250
if you were speaking of me about the PSI thing.. psi really never matters... i was just giving a relative thing, it's all about blower efficiency and CFM..
how's your build going?
Back on Topic
1. So your company will have no problem allowing us to pick what parts we need from the kit if we find parts else where?
^^ That isn't to mention you could probably find an M62 for quite a bit cheaper, which is the biggest chunk out of this.
With that said, I'm still planning on Hahn turbo with a pro install for my 2.4l..
My build is going... Just trying to get the engine from denver to here then i get to throw in the pistons/rods and swap it in.
No man i know you know what your talking about, just everyone kept making it seem like the m62 can still put out 19psi on the 2.4 engine and be at like 300+whp and still be in its efficiency range. Thats completely wrong and i wanted explain why. I just hope people realize that you will only get 14psi, maybe less out of a 2.7 - 2.5 pulley on the 2.4 engine. Thats exactly why you only see 7.5psi on the 2.4 vs 12psi on the LSJ.
if you're looking for 300WHP on the M62 it's possible but you'll be over spining the hell out of the blower however it should be possible ... i feel like you'll be maxing out at like 15PSI and close to 290HP on the blower before it starts to get ridiculous heat soak. regardless this should be a bit better than ss/scs I couldn't imagine how much the car would put out with meth or an ice box, dual pass, 2.7 pulley, full exhaust, intake and tune haha that would probably kick ass, and if you do the installs yourself it wouldn't be much more than the hahn kit i would think... it all depends on your power goals... the twin screw give a bit more potential but if you want alot of HP you're going to be hard pressed with a TS or roots on these cars, since the blower would be bigger the more HP you want..
don't worry wasn't taking offense just i'm usually posting quickly at work... and I don't work in a cubicle so it's obvious when i'm typing depending on where my boss it haha...
usually njhk cleans up my half jumbled statements and fills them out a bit more
in all reality the m62 will be your cheapest setup... with how many wrecked redlines and ss/scs there are and the fact that more and more people are doing swaps you should have no problem getting parts... and still 2900 before tuning is a rocking deal, the only thing I know thats a better deal is ionjenztchs turbo kit haha
my advice to people thinking about going this route... do major planning.. see how much HP you want as a goal and choose, because if you think you're going to be pushing out 350-400hp on this system Crank or wheel, it's not going to happen with some major work, the twin screw would help.. but unless you get that right off the bat that will be another 2K or so for the upgrade.
however depending on the dealership you might be able to con them into warrantying it hahaha
haha
Last edited by elecblue06; Jul 25, 2007 at 03:31 PM. Reason: Automerged Doublepost
ryan.
im an idiot g5 duh but is it for the g5 sc or 2.4?
now this is for the 2.0 supercharged i read most of this thread so im assuming it is. unless they can fab up something so this can work with the 2.4 i wonder buy the hahn turbo kit and this for the 2.4 you think that would be possible hmm this would be something im interested it well 350whp wouldnt be to bad lol.
ryan.
ryan.
is it possible to run this sc setup and then run a hahn turbo setup with proper tuning and dyno time that would be some serious whp like 350 of course with new clutch tires and all extremities. what you think
ryan.
ryan.
sorry read it wrong 226whp thats decent for a what stock 2.4 eco. now will this setup work for the cobalt its basically the same thing just maybe different computer for the cars weight and such i dont know.
but add a turbo to that sc kit your lookin at high 200s or 300whp even.
If all I have to do is spend a day turning wrenches on my car then yes I will get this one. The Hahn kit looks fine don't get me wrong but a couple of things I'm not hot on. First and formost they ran the piping above the top of the engine, NOT a very pretty package and IMO about 1/2 of what a car is is its looks. I don't want to pop my hood and not be able to see my valve cover thru all their stuff. Secondly I have to ship them my ECU and be without a car for 3 DAYS! 3 DAYS? No thanks! This "kit" I can install myself, cruise veeeeery gently up to Tune Time in Jersey and get the car re-flashed by them useing their stuff for about the same price as Rebel wants.
This "kit" just seems to be a better option for me.
lol first he says im the first to go turbo with hahn kit lol now this lol
ryan.
ryan.
Why do that when you can go twinscrew and hit arouond 300+?
ryan.
ryan.
and yes it should work.. hence why it was posted here haha. this setup will work for the balt, ion, and g5.. it would just be a matter of the custom parts maybe being slightly different, tuning would be different but long as you can tune it itll be fine.
yea it is nice to get everything broken down... hell if rebel sold the custom parts and the instructions for a fee I'm sure they could make some money off it even if they don't sell the whole kit. the sc just seems more like a user friendly install / maintenance package. I wanna see some it pushed till it pops because I don't wanna be the one to find that out hahah so wait jack... there's no way for you to tune cept tune time? don't you do HPtuning?
twinscrew im not to knowledgable on this i dont know what that is elighten me. well with the sc and turbo might be interesting but it might be to much of a problem is all. but this sc looks very nice clean and i like the black look of this sc other then the gm stock one for the 2.0 cobalt.
and its really cheap to0. i think it is anyway.
twinscrew is what now?
ryan.
ryan.
ryan.
ryan.
twincharging is a waste (IMO) and a custom job
throttle body and stuff included i read the parts list i dont know but seems interesting. if i could give you rep jacko i would it wont let me lol.
ryan.
google is your friend if you need anything more about it
god damnnnn people are ninjaing my replies haha
and for a little more in depth it's similar to a roots however because of the "twin screw" design it creates an internal compression which actually helps keep the temps down because when it goes into the manifold the air cools instead of like the roots where it just spins the air but doesn't compress it so it just shoots out blazing hot air haha.
i would like the whine in my 2.4 but then i like the chsssssh! when i shift with the turbo hmm i dont know.
ryan. i could borrow some money and get both lol
