swappin auto to stick
Old Aug 10, 2007 | 05:47 PM
4doorcobaltowner's Avatar
hey guys...i recently swapped my civic to a 5speed..took a little bit of research and work..relativly easy...i have a 06 ss auto...and i went to the dealer to get all the diagrams of a 5 speed cobalt...and it doesnt look that hard at all...just the wiring for the tcm...and the ecu..not quite sure if you can just get the 5 speed harness..and all the cobalts have the same ecu's i guess there all just tuned at the factory for the car model..5 speed or not..an i found out that the 2.4 and 2.2 use the same transmission..and they use sabb transmissions...the ss/sc is completly different...so im wonderin if i can find any base model cobalt thats smashed and just get a 2.2 5 speed tranny and go that route...im just pricing stuff out..im definatly going to attempt this...any info would be great guys...
Old Aug 10, 2007 | 05:51 PM
monkeiboy's Avatar
I'm pretty sure that your dealer will void your warranty for doing this. You might consider trading in if it's THAT necessary for you to have a manual. After the final cost to you is tabulated, you won't be that much more out of pocket than a transmission swap and you'll still have the warranty
Old Aug 10, 2007 | 05:52 PM
an0malous's Avatar
you should stop buying automatics?
lol
Old Aug 10, 2007 | 06:03 PM
bigworm's Avatar
it was a major pain in the ass finding my 2.4L 5spd, I almost went down this route myself...
I had sales people tell me: "you WANT a manual on purpose?!? Why?!"
californians are lazy.. gimmie big suv, lazyboy on wheels.
Old Aug 10, 2007 | 06:05 PM
already the comments i knew would come...anyways...civic was givin to me for free and i did it all myself cuz my buddy did it and i learned...not tradin it in because its simple i CANT....i bought to many cars one after another...and what i owed kept goin on top of the bill...so i owe more then the cars worth by alot...so i want to make it worth the while...and price wise is not that bad...just the transmission really and gettin performance clutch kit...i just wanted to know if anyone has an idea of this and if someone has attempted it
Old Aug 10, 2007 | 06:26 PM
DrPuttsSS/SC's Avatar
How much did it cost, how hard was it to do to your civic?
New transaxle at this site: http://www.trademotion.com/partlocat...06&catalogid=1
Another thing to consider is that if you plan to mod your engine you may want the SC transaxle with the LSD.
I want to add the LSD to my car. It sucks that by the time I pay almost $1000 for the unit, if I can't install it myself (which I plan to do) installation costs so much that I'd be better off buying a whole new transaxle ($1905) with it already installed.
If I do that I'll have my stock T/A for sale, 14K miles.
Last edited by DrPuttsSS/SC; Aug 10, 2007 at 06:26 PM. Reason: Automerged Doublepost
Old Aug 10, 2007 | 06:35 PM
it only took 1 day to do the civic...and another day of tuning and bleeding and little stuff....very easy in my case..except for the first drive down the road and hit 3rd gear and bammm grind....syncro shot...niceee drove it like that for a month got a good tranny that sat for a long time...take it out and put another one in...then it dont go in gear...take it out again check everything put it back...still dont go in gear..PISSED...so i say screw it power shift it....all of a sudden few days later clutch starts workin right and goes into gear...and day by day it got really smooth...and then it was perfect...and i used royal purple syncromesh....and price wise was like 500-700 bucks... all stock stuff and junkyard stuff
i just really need to know if i can order the flywheel and clutch kit...for either the 2.2 or 2.4..because they are the same so i can just use any one right?? and just wonderin if i need the whole pedal assembly...and if there is already a whole in the floor for it all...and hardest part is cancelin the tcm and wiring....
Last edited by 4doorcobaltowner; Aug 10, 2007 at 06:35 PM. Reason: Automerged Doublepost
SlifoxS's Avatar
let me know how this goes
Old Aug 10, 2007 | 07:33 PM
IonNinja's Avatar
the 2.2 and 2.4 both use the f23 transmission and there are no variances between the two to my knowledge so you should be able to work with any f23 tranny
Old Aug 10, 2007 | 08:07 PM
Brucesblack's Avatar
id like to see this happen !! .. listen to IonNinja he know's what he's talking about !!
Old Aug 10, 2007 | 08:20 PM
steddy2112's Avatar
I thought the final drive was different on the 2.4???
Old Aug 10, 2007 | 08:23 PM
Jimmys2007CobaltSS/C's Avatar
is it that hard to find a 2.4 manual?
Old Aug 10, 2007 | 08:44 PM
24SSNighthawk's Avatar
yeah i had to drive like 130 miles to find my 2.4 manual
Old Aug 10, 2007 | 08:50 PM
Shortbus's Avatar
Doing a swap on a civic, and doing one on this car, is like apples to oranges.
Old Aug 10, 2007 | 09:08 PM
yea what he said ^^ listen to Shortbus he's a good guy !!
Old Aug 10, 2007 | 09:13 PM
alleycat58's Avatar
Your research is incorrect in a couple areas:
1) The 2.2 and 2.4 DO NOT have SAAB transmissions. You're backwards. The 2.2 and the 2.4 have Getrag transmissions and the SS/SC has the SAAB transmission from FGP (Fiat-GM Powertrain).
2) The 2.2 tranny and 2.4 tranny are slightly different, the 2.4 has a different final drive. I'd try and stick with the 2.4 manual if you could.
Old Aug 10, 2007 | 09:18 PM
DarkSergeant's Avatar
My 2 cents? Spend the money you'd spend on this on forced induction or some really nice appearance mods. Have your car tuned so the auto tranny is more to your liking and you likely won't mind.
The enjoyment factor between an auto and a 5 speed isn't THAT great to spend the money or time on a brand new, warrantied car.
Outside of that - look on here, craigs list, ebay, whatever for someone that will trade you straight up auto for 5 speed. I'm sure there's somebody that would be willing to do this, for whatever reason.
The absolute *BEST* idea I can give you? Use the money to dig your ass out of debt. If you have multiple cars piled on this loan, you probably have a garbage ass interest rate - any money you can help pay that **** down will be money saved down the road.
Old Aug 10, 2007 | 10:33 PM
Halfcent's Avatar
I'm old school
We have addressed this issue in the past. The problem is cost. It is actually cheaper to just trade your existing car for one that has a manual trans. It make no sense financially to take apart a warranteed car when for less money you can trade it for another warranteed car.
And all Cobalts do NOT have the same ECM. In fact, each engine type uses a different model computer.
Old Aug 10, 2007 | 10:39 PM
alleycat58's Avatar
Good call, I completely missed that part of his post.
Old Aug 11, 2007 | 02:24 AM
monkeiboy's Avatar
Totally missed him saying that too....That's Halfcent...with his damn eagle eyes and insightful commentary
Old Aug 11, 2007 | 10:00 AM
iLLmaTic3s's Avatar
halfcent is the man..and tells how its going to be all the time, ur the man
Old Aug 11, 2007 | 11:48 AM
well i was at gm and he told me all the computers were the same...just programed to the car at the factory...and he told me right from the computer that there both sabb transmissions...and anyways im still going to attempt it an im sick of hearing trade it in...how bout some help full information...like some of the wiring i need to do...thats my basic concern everything else is pretty simple....im going to find a smashed base model and use the 2.2 tranny...get the linkeages...get aftermarket clutch kit and flywheel...short shifter...grab the pedals...and get the master and slave all new from gm cuz i get discount...and the rest is pretty much if i can use the stock axles on the 5 speed tranny...and wiring....not gettin rid of the car i cant... simple..so if you dont have any info for me dont bother....
Old Aug 11, 2007 | 12:18 PM
Halfcent's Avatar
I'm old school
No need to get upset. I was sharing a very helpful and true piece of advice with you.
To my knowledge no one on this board has done the swap. Besides needing the obvious hard parts, you are probably going to need reflashes for both your ECM and BCM. The ECM for certain has a software selectable switch via Tech2 that tells the car if its a manual or automatic, and what tire size it has. At least on the L61 program it does. On your LE5 it will be a little different.
I assure you each different engine has a different kind of computer. Read this thread:
https://www.cobaltss.net/forums/tuning-131/ecotec-engine-management-summary-w-pinouts-38412/
Old Aug 11, 2007 | 12:23 PM
im not i just knew everyone would say trade it in...i would and i wouldnt keep the car...i would prefer a sti..or a infiniti m45...but i cant do that...so i want to keep mine..i get so many compliments as it is bein a clean 4 door so i just want it a stick...i know i can do it just wanted some helpfull advice on wiring..i seen some info on it before but cant find it...i know everyone at gm...and they can always get my diagrams and parts for cheaper so..im ready for it...
Old Aug 11, 2007 | 06:24 PM
Spacebar > ...
bigdeertz
Nov 17, 2016 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
lendsley
Sep 22, 2015 10:48 PM
Shane H
Sep 20, 2015 11:56 AM
