Torque Damper - WTB
Torque Damper - WTB
What is the best torque damper out there that fits a 2.4, and which is the cheapest?
Which do you recommend + easiest install?
Also, what are the disadvantages of a torque damper?
Ingalls or Weapon R?
meh
not too many vibes unless you do a lot of idling
wrong section by the way
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/before-you-post-2-4-tech-section-read-35813/
Ingalls and the TTR mount have the same amount of vibs...
Ingalls has structural issues and can bend the brackets.
TTR mount has never had any structual issues.
Many have bought the Ingalls, and the switched to the Turbo Tech Racing mount; They stated they would never go back to the Ingalls.
i have all 3
ingalls is the only one i've seen made for these cars. i've heard of them having defects, but if you install them right, you shouldn't have a problem (i've had mine for 20k miles and it's still ok) you can get this from any vendor on this site.
buuuuuuuuuuuuuut.... i would highly go with TTR's engine mount and tranny inserts. the TD doesn't hurt tho
ignalls td is eaisest and hes right if u install right its great. i bought it used and the guy who had it b4 me had adjusted the stiffness and didnt let out the shock arm and when i installed the car vibrated like a ****. but i adjusted it and lengthened the shock now its great works good and has little to no vibration.
just think of it as payless vs nike shocks and you being someone who likes to run. yeah the payless shoes will work but youll thank yourself later for not being a cheap ass and going with the nikes. lol.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
