tuning a stock 2.4
I say just go with Trifecta, or hit up 'ol man river Joe Rutledge (BennyHHR) and have him HP Tuners tune you.
interesting....my car is mostly stock, ive got an aero turbine exhaust on it and short air intake, thats about it...if i were to tune this car would it even make a difference?
The Psykosteve 30 ft lb torque gain was on a RWD LE5, and the stock torque numbers were way lower than they should have been for some reason. Plus they were not peak numbers, they were the numbers at 3000 RPM.
I am going to have to talk to those LS2 Edit guys and see if that will work, truly, on the 08s cause if it does then that is my path.
The only trick with LS2 Edit is that ECM is locked "to" the programmer. If you buy LS2 Edit, and have a tuner use your program on your laptop, then your O'K. If you go to a tuner who uses LS2 Edit, on their laptoip, then you always have to go back to that tuner to revise your tune. You cannot adjust it yourself. If you want to return to the stock tune, you still have to return to the original tuner. Also with HP Tuners, you can use anybody's tune on your engine.
There is a statement on the LS2 Edit website that may help to explain this. copied and pasted:
A word of warning: Please only program your E/TCM using an LS2 file that was read from your specific E/TCM. Do not try to program your E/TCM with an LS2 file from a different E/TCM. To minimize programming time, we do not completely reprogram the E/TCM, only the data segments. If you use a different LS2 file, the data in the LS2 file may not match the code already stored in the E/TCM. If you attempt this, you may end up with a E/TCM that is non-operational.
yeah I bought a laptop just for tuning so that isn't an issue and I would keep a baseline file untouched so I could always go back.
The trick with something like HP tuners, is that you can share files, and obviously, compare results. With LS2 Edit, you cannot share files.
One other item I have no idea about, is what are the differences in the tables between HP Tuners and LS2 Edit. Is one more detailled, or more customizable than the other? Is this even important? (This could open up a whole other can or worms. LoL.)
Well, I am really intrigued. The big problem from my standpoint, is that in southern Ontario, Canada, (my turf,) there are only a few tuners who use LS2 Edit, and they specialize in V-8 gas, diesel and turbo diesel Trucks. Where as there are a number tuners proficient with HP Tuners, since the SC and early 2.4's have been supported for years.
So do I go for LS2 Edit, and the long learning curve, or wait for HP Tuners, and lots of local help?
HP Tuners will w/o a be doubt making a tuning program for the '08 model LE5's.........its just a matter of when. But yeah, I suppose I don't blame ya for wanting to wait.
Yeah I am emailing back and forth with the guy right now. And from what I have seen in the user manual and screen shots it looks pretty straight forward.
Gotcha. Yeah, I suppose that was the beauty of having someone else tune mine. All I had to do was drive. He did the rest. He data logged some normal driving, data logged some aggressive driving.........took a break.....reviwed the data on his laptop....made some adjustments........rinse and repeat until the sun went down and the car was running smoothly.
