Turbo ?
Old Jan 24, 2006 | 11:00 PM
jerryg's Avatar
Turbo ?
has any 2.4s put a turbo on their cars. I read something about one from maximus that fits our cars. Only gives us like 4-5 psi. 40-50 horsepower. anybody think this will be a good idea. only costs $2300
Old Jan 25, 2006 | 05:39 AM
Brandon97Z's Avatar
maximus? who the hell is that
Old Jan 25, 2006 | 06:37 AM
EricTF28's Avatar
I think it's a Nissan. :P
Old Jan 25, 2006 | 10:41 AM
RaineMan's Avatar
I haven't heard of any major parts manufacturers making aftermarket F/I systems for our cars yet... I don't think anyone has cracked the VVT codes...
Old Jan 25, 2006 | 11:04 AM
Brian MP5T's Avatar
Although, VVT and Boost applications do not work together. On a stock engine that has high compression, it is possible to leave it as is and run low boost. The thread starter said 4-5 Psi...
As long as some sort of fuel management is taken into account and the turbo is never to go over 4 or 5 at most, the VVT will not prove to be a major problem.
The only thing that I am not aware of that you might want to look into is how "Active" the stock ECU is. On My Mazda, the ECU is rather simple and does basic functions like run the ignition timing and modify fuel delivery. If the ECU on the 2.4 is very active and sees boost, it might think something is very wrong with the sesnors and cause "Limp Mode"
You would trigger CEL.
I agree with Silver Streak. The ECU has to be taken into account for any kit that would be made for the 2.4
Old Jan 25, 2006 | 12:15 PM
celicacobalt's Avatar
well if vvt and boost dont work together then why is the supra such a powerful car?
Old Jan 25, 2006 | 11:12 PM
jerryg's Avatar
lets hope they figure out something soon
Old Jan 26, 2006 | 05:46 AM
Brian MP5T's Avatar
Are you saying "Stock"
cause if not my answer is aftermarket engine control.
In the case of Stock, it was part of the design from the get go. GM is not about to start designing diferent ECU's just to that it's owners can just fire Turbochargers etc on their cars.
Fundamental Diference is that one comes with a turbo and has been designed with that in mind. The stock ECU on the 2.4 is an N/A car, it will perform like one. Adding a Turbo to a Stock N/A ECU has to be planned, N/A VVT is not something I would start High-Boosting
Old Jan 26, 2006 | 10:12 AM
i agree with that but i mean im sure the aftermarket will pick up here pretty soon so that high boosting can be done i just wanted to clarify thta high boost and vvt are still a viable option with the right tuning, although im probably gonna just be good for a while on 6-7 psi on stock car
Old Jan 26, 2006 | 04:19 PM
Dragonsfire12345's Avatar
didn't a performance company put a turbo on a HHR? They did it on Rides, I think it was black horse performance or something. I'll check it out
Old Jan 26, 2006 | 04:23 PM
yeah definately let us know what you find out on that i havent watched rides for a while
Old Jan 26, 2006 | 04:54 PM
well heres one sight of the HHR with the turbo but I can't find the main page for darkside performance yet. Heres the page of it http://www.hhrclub.org/galleries/hhr...-by-dark-side/
Old Jan 26, 2006 | 05:14 PM
still searching cuz I have nothing else to do lol I found this on motor trend dummies don't know the difference of a 2.2 and 2.4 lol anyways I found this and the kit gave the HHR 71ponies. I wonder how much PSI they are pushing. NOTE: this is a rear mounted turbo and they are impressed with the power and with the low turbo lag. Anyways it also has a web page for the company who made the turbo. For the HHR it says it cost 4000bucks. Not bad in my opinion for 71ponies. So my search continues. I might be on a roll here.
Old Jan 26, 2006 | 05:21 PM
fukuhos's Avatar
hahn racecraft is in progress in making a turbo for our cars i get my kit put on in 2 months...
Old Jan 26, 2006 | 05:26 PM
sounds good how much is it?
Old Jan 26, 2006 | 05:31 PM
fukuhos's Avatar
around 3thousand
Old Jan 26, 2006 | 06:09 PM
Armorsquadbliss's Avatar
Heh that HHR is powered by the STS turbo system which i based my thread on as brian may know. It is a 2.2 engine.
Old Jan 27, 2006 | 12:46 AM
r u sure cuz it has ECOTEC VVT on the valve cover. See....
this is the 2.2 notice the difference on the valve cover...
so the engine in the HHR couldn't be a 2.2
Old Jan 27, 2006 | 01:07 AM
artawesome's Avatar
this might be a good time to ask-the 2.4 has force induction-which gives it more HP the the 2.2, so what is force induction? can a turbocharge beable to fit both the 2.2 and the 2.4, or will there 2 different turbos to fit both engines?
Old Jan 27, 2006 | 01:32 AM
G4_mexico's Avatar
Why is a line going from the fuel rail to the intake-throttlebody ???
Old Jan 27, 2006 | 03:33 AM
I never seen that pic before. I'm amazed motortrend would screw up that badly if it is a 2.4l. i would write into the magazine if i really really cared lol. I guess we ahve to assume that it is the 2.4L. How much HP does this engine put out?
Old Jan 27, 2006 | 03:46 AM
If that is a 2.4L then the STS system only gave it 40 something extra horse is that really worth 4 grand?
Old Jan 27, 2006 | 05:12 AM
Brian MP5T's Avatar
It has an extra injector mounted in the intake. It's address fuel management, alot better than most kist whic just fun an FMU. #1.
Old Jan 27, 2006 | 09:51 AM
well i still dont like the idea of rear turbo charging but i am glad that these cars are getting kits out so thats cool.
Old Jan 27, 2006 | 09:55 AM
Vita's Avatar
correct. it actually looks like a nice setup, though the cost is mostly due to the extensive piping they need to do. i'd wait for a "real" turbo kit.
those rear mount turbos are decent on big v8s, but i'd stay away from them on a smaller engine if you want big power. for the average consumer, it would be fine though.
personally, i'm holding off for a supercharging solution. either that or just swap in an LSJ...
