Typhoon Install?
Old Jul 10, 2009 | 11:30 PM
comptekkie's Avatar
Typhoon Install?
Getting ready to install the K&N Typhoon sri on my 06 SS/NA and need to ask if I should take out the small black plastic inlet duct/resonator assembly that connects to the bottom of the factory airbox, it is separate from the airbox but connects to it by a plastic tube and sits behind the right tire splash shield. It doesn't mention this in the Typhoon instructions.
Old Jul 10, 2009 | 11:48 PM
Dunkinuts's Avatar
You don't have to, but I removed every part of the factory intake. I wont hurt anything staying there but it definitely wont help staying. If you remove it you will understand why I say that.
Old Jul 10, 2009 | 11:53 PM
06SIBLT's Avatar
I would remove it, weight reduction, although it is minor every bit helps. lol
Old Jul 11, 2009 | 12:58 AM
wollis1's Avatar
ive tried to remove it but its a pain in the ass. i didnt notice it really until after i put the intake on also. whats it being held on by, just 2 bolts? i found the one easily when i had my headlights out, but the second seems out of reach
Old Jul 11, 2009 | 06:35 AM
hailcesar75's Avatar
Old Jul 11, 2009 | 12:35 PM
LastAXEL's Avatar
I really wish mine was out but I didn't really think about it until after I put the Typhoon on it. So, alas, it staying in there until I grow out of my laziness.
Old Jul 11, 2009 | 06:52 PM
comptekkie's Avatar
I wasn't sure if it effected the amount of air going to the area of the K&N filter? Since it is called a Fresh air duct/resonator.Thought maybe it brought in more of a flow of air to the area, if I removed it there would just be a hole in the metal under the Filter. I think I will just take it out.
Old Jul 12, 2009 | 09:57 PM
hamann80's Avatar
didn't take mine out.
Old Jul 12, 2009 | 11:21 PM
tambrico's Avatar
I took mine out afterward because I dropped a coin in it by accident and I wasn't sure what it was or where it went, hahahaha. It was somewhat of a bitch to get out though.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
