Upcoming 2.4 SC build - Build questions
Old May 28, 2011 | 12:01 PM
CordiaDOHC's Avatar
Ok so we are going to see before the end of summer what an 08 2.4 can handle.
The car:
2008 Cobalt Sport 2.4 LE5 Auto coupe (51,xxx miles)
Heres the plan
Supercharged setup:
ported m62
ls4 throttle body
intake (working on those details...)
80lb injectors
2.6 pulley
zzp shorty header
zzp 3 inch reduced to 2.5 catted downpipe
slp loudmouth catback
dual pass
option b
Now one of my questions is on the injectors. Can I run the ev6 80lb injectors without an injector harness upgrade?
I am an auto so not sure how that will play into power but my power goal is 270-300whp. Which is probably beyond breaking point for a potentially non forged 08 2.4 LE5
But if it blows it will blow in a glorious way!
Old May 29, 2011 | 02:36 PM
EUGENIO's Avatar
r u
r u going to change all your pullys to 6 rib
Old May 29, 2011 | 02:46 PM
NJHK's Avatar
Seriously, don't go 2.6 on a M62...it would be extremely inefficient.
Old May 29, 2011 | 02:55 PM
kxrida2000's Avatar
and lose the ls4 tb
Old May 29, 2011 | 04:25 PM
CordiaDOHC's Avatar
Originally Posted by kxrida2000
and lose the ls4 tb
THe LS4 was only proven not to work well on the LSJ not the 2.4 which has higher compression as well as added displacement.
I realize a 2.6 is hard on the m62 as well as creating a good amount of additional heat. However between e85 and the cooling upgrades I should be in good shape.
I will start off at 5 rib if I have any issues I will switch over to 6 rib.
Old May 29, 2011 | 06:38 PM
EUGENIO's Avatar
from where
where r u getting a 5 rib pully from i got my kit from zzp but i been wanting to get the stage 2 kit
Old May 29, 2011 | 06:40 PM
heathkidder's Avatar
jus cut one off
Old May 29, 2011 | 06:45 PM
CordiaDOHC's Avatar
you can run a 6 rib pulley if you want to run a smaller pulley. Thats what im doing. Running a trimmed 5 rib belt on a 6 rib pulley.
Old May 29, 2011 | 07:03 PM
kxrida2000's Avatar
i ran it on my 2.2 it doesnt like it trust me lol the lsj tb is plenty big enough for how much air u are gonna flow
Old May 29, 2011 | 07:41 PM
EUGENIO's Avatar
so
so u can run a 5 rib belt on a 6 rib pully dam
Old May 29, 2011 | 11:41 PM
CordiaDOHC's Avatar
Theres at least one 2.4 guy on here running an LS4 tb and likes it. But the LE5 still has a bit on an L61.
Old May 29, 2011 | 11:53 PM
Pedobear's Avatar
yeah for 2.2s its the only option if you dont want to completely swap to 6 rib pulleys. you think you would lose 1/6 of the traction on it but it holds fine
Old May 30, 2011 | 09:50 AM
manny45's Avatar
well us 2.4 guys can drop a lil bit less... for example LSJ guys stock boost level is 11psi and we are 9psi. so he might still be in the efficiency range still.But it will be close to the whole blowing ur engine. im real interested to see how it works out for u! Oh a suggestion I would get a tranny cooler to help ur tranny being auto like myself. I love the power and I plan on going with what u listed in the future just dont have money saved up if it blows the engine u know,
Old May 30, 2011 | 12:20 PM
CordiaDOHC's Avatar
Maven and a few others recommend against using a trans cooler as it can cause issues. So unsure on what I want to do about that.
Old May 30, 2011 | 12:28 PM
manny45's Avatar
well I have ran mine for about 2 months now and no issues here... our tranny is pretty strong and i honestly didnt need to put it on there just yet but was told my guy to do it to be on the safe side. What issues came up with the cooler?
Old May 30, 2011 | 12:33 PM
Spanky's Monkey's Avatar
i run a built trans and no cooler. i would not recommend a trans cooler either. i would however recommend getting the tranny built to handle a fair amount of torque and hp.
Old May 30, 2011 | 12:36 PM
CordiaDOHC's Avatar
Im honestly not sure. Id have to go back and find mavens response to that question.
Built engine and trans are hopefully planned for next season. But this season its all about seeing what their limits are!
manny45's Avatar
why do u go against it?
Old May 30, 2011 | 12:39 PM
CordiaDOHC's Avatar
My memory is horrible. I just remember what maven said making sense.
Old May 30, 2011 | 02:27 PM
OttawaMark's Avatar
Time for Maven or whoever recommends against tranny coolers to chime in before the anti-cooler meme becomes defacto fact. I've googled the issue extensively and have found basically zero evidence to support not having one. Even ZZP recommended one for my SC kit. If foaming is the issue get a good 'flush' (really just a full drain of ALL oem ATF) and add full synthetic, wynns or amsoil ATF.
Old May 30, 2011 | 02:28 PM
Pedobear's Avatar
i didnt see the OP mention anything about meth
Old May 30, 2011 | 06:22 PM
OttawaMark's Avatar
I think the OP is gonna go E85. With a 2.6 he'll need it.
Old May 30, 2011 | 06:55 PM
Pedobear's Avatar
ah still meth will help
Old May 30, 2011 | 08:25 PM
gbkglenn's Avatar
i'm building my 2.2 and running a 2.7 not my dd but i go on 6 hr trips some , think i'll be ok ?
Old May 30, 2011 | 08:28 PM
Pedobear's Avatar
thats pushing it on stock internals.
