UPDATED 2.4L Performance Modification List
Intake: The stock air box is highly restrictive. Freeing this up would provide more air for combustion and increase power output
- Cold Air Intake
- Short Ram Intake
- Intake Manifold
Exhaust: The less restrictive an exhaust setup is, the more power will free up from an engine. Our 2.4 stock exhaust system is decent (has 2.5" piping), but it is restricted by the header, cat (in the downpipe), and the exhaust section from rear wheel back (which becomes 2.25" piping and has a restrictive muffler)
- Header (Exhaust manifold)
- Long Tube (high-end gain)
- Mid-length (mid gain)
- Shorty (low-end gain)
- Turbo (for turbo applications only)
- Downpipe
- Catback
- GM Performance Parts (Performance/Touring) Videoclip
- Corsa (Sport/Touring) Videoclip
- Magnaflow (either 2.25" or 2.5") Videoclip
- Megan Racing PIC
- SLP Loudmouth II Videoclip
- SLP Loudmouth II Dual Outlet Videoclip
- JBP Vortex 3.0" >>
- Pacesetter Videoclip
- Ark Racing N2 (not produced anymore) Videoclip
- Ark Racing DT-S Videoclip
- Ark Racing GRIP INFO Videoclip
- Tusdo N1 >> Videoclip
- Borla Videoclip
- Hahn Racecraft 3" >> Videoclip
- Clear Image Automotive (either 2.5" or 3") >>
- Stainless Works >>
- CTI 3" Videoclip
- ZZP 3" >>
- Custom piping >>
Engine: (requires tuning)
- Forced Induction
- Camshaft
- JBP Tri flow camshaft >>
- Custom regrind
- Nitrous
- NOS
- Nitrous Express
- Zex
- Holly
- Vemon
- DynoTune
- Throttle Body
- Throttle Body port/swap
- Individual Throttle Body kits
- ZZ Performance Throttlebody adapter plate >>
- Injectors
- Cylinder Heads
- Pistons
- Wiseco
- Connecting Rods
- Electrical
- Jet Performance Chip MAF sensor
- Crate Engines
- JBP LE5 Performance crate engines >>
Pulley
Transmission:
- Manual
- Short Throw Shift kits
- TWM Short Shift Kit
- B&M Short Throw Shifter
- Ark Performance
- Any STS kit for the Getrag Transmission in some 2.4L and all Ecotec equipped Cavaliers will fit the 2.4L manual transmission INFO (Some may require slight modification to fit properly)
- Clutch Kits
- Exedy Racing
- SPEC
- Competition Clutch
- Flywheels
- Fidanza
- SPEC
- ACT
- LSD (Limited Slip Differential)
- Quaife
- Miscellaneous
- Automatic
- B&M Shift Plus INFO (for late 06+, wiring is a bit different)
- Transmission Tune
- Quaife
Tuning: Our stock engine tune is rather conservative. Tuning parameters like power enrichment delay, air to fuel ratio, and spark timing will result in decent horsepower gains. Tuning after installing bolt ons (intake and exhaust) will further bring out the potentials of those modifications
- Tuning Equipment INFO
- Canned Tune
Legend:
>>= Link to product
Videoclip= video
PIC= Picture
INFO= Additional information on product
OK I think I got everything that wasn't added from the last thread. If you see something missing just post it up and I'll add it. Also if you have a video clip or picture of your exhaust that isn't already up please post the link and I'll add it.
Last edited by riko540; Feb 28, 2010 at 05:27 PM. Reason: cleaned list up and added info
try and get some brands for the STS
JBP has stage heads
LS2edit for ecu tune
for nitrous any of the brands, Zex, Vemon, Holley, etc. etc.
also Bassani makes a cat-back.
I know there are intake manifolds as well.
JBP has stage heads
Added and they also make a cat-back exhaust system too.
Yes they do, added them
I can't find Bassani's cat-back on their website. If you know where I can find it post the link.
what about speed mafia procharger kit.. just needz some cobalt guy to step up and get the piping setup
and trifecta shouldn't be under canned tunes
Last edited by elecblue06; May 16, 2009 at 12:04 PM. Reason: Automerged Doublepost
I was waiting for you to post cause I couldn't remember the who made the procharger kit lol. Its been added and I moved trifecta and I think I'll rename it also, so not to confuse people.
for short throw shifters you can add that we can use the same ones made for cavys.. i have one..made a thread also...
https://www.cobaltss.net/forums/drivetrain-79/short-throw-install-2-4s-155073/
https://www.cobaltss.net/forums/showthread.php?t=155073
Hey guys there might be a link or two that dont work, if you come across any that dont work let me know.
