Vibrant header/dp combo fitment for 2.4
Old May 5, 2009 | 08:01 AM
Smiles's Avatar
hey, has anyone installed the vibrant header/dp for the 2.4 with the stock exhaust system, and is it a direct fit.
I called Performance Improvments and they said that it would take some modifications, but on the cobalt addiction website they say its direct fit. Is it, or is it not?
Old May 5, 2009 | 08:30 AM
Ercegs07SS's Avatar
Originally Posted by Smiles
hey, has anyone installed the vibrant header/dp for the 2.4, and is it a direct fit.
I called Performance Improvments and they said that it would take some modifications, but on the cobalt addiction website they say its direct fit. Is it?
Also wondering the same thing, any info would be great! Im looking to get the cobalt addiction header and a unknown catted downpipe. Buying it from a local cobaltss.net member who used to have the ss/na and just got the 09 ss/tc.(Luckey bastered, lol)
Old May 5, 2009 | 09:34 AM
Smiles's Avatar
I've heard so many different things about this. Some ppl say its a direct fit and others say I need to modify.
It would be nice to hear from someone that has done this to a 2.4.
ss/tc sounds nice
Old May 5, 2009 | 11:31 AM
Dunkinuts's Avatar
I think it really depends on the year of your cobalt.
Old May 5, 2009 | 11:34 AM
diablo9287's Avatar
and if ur an auto or manual if a manual should have no problem auto it might come up short
Old May 5, 2009 | 11:58 AM
cwlaser90's Avatar
installed mine last week to my 06 ss 2.4 5spd. No fitment issues bolted right up.
Old May 5, 2009 | 01:11 PM
Ercegs07SS's Avatar
Awsome man, thanks. That helps alot. How loud is it??
Old May 5, 2009 | 02:14 PM
Smiles's Avatar
Excellent! I'm going to get it. How does it sound? Did you bolt it to the stock system?
Old May 5, 2009 | 02:30 PM
Ercegs07SS's Avatar
ATTENTION!!! I just read this on TURBOTECHRACING.COM........
NOTE: PLEASE READ THE FOLLOWING:
Fits all 2.0 SS/SC Models 2005-07 with no modifications, 100% bolt on.
Fits the 2.2/2.4L Cobalt if your car does not have the SAI (Secondary Air Injection) Please check to make sure you do not have SAI before you order, as returns will not be accepted for this reason. SAI came on some 2006-09 Cobalts. 2.2/2.4L Cobalts built in 2005 should not have SAI (please check yours, before you order to make sure).
Old May 5, 2009 | 06:12 PM
cwlaser90's Avatar
how do i know weather i have SAI? as for sound, it sounds great. added alittle more rumble to the stock ss exhaust. i was scared at first because i didnt want it to sounds raspey but im very satisfied with the way it sounds. works great with the k&n intake system i installed also.
Old May 5, 2009 | 06:40 PM
Smiles's Avatar
I think SAI is an extra little hose that comes out of you stock air box. Mine doesnt have one.
I didnt want a raspy sound either, so this will be perfect. Did you install it yourself? Was it difficult?
Old May 5, 2009 | 07:04 PM
mmcgee123's Avatar
ya I'm pretty sure it goes from ur airbox to ur exhaust mani intended to heat up the cat faster I THink
Old May 5, 2009 | 07:20 PM
cwlaser90's Avatar
yea i installed it. Wasnt hard at all really. pretty striaght forward. A impact made it alot easier tho instead of having to break them loose by hand. The head bolts will come off with little effort by hand tho.
I noticed when comparing stock manifold to the vibrant header, my stock one had a port on the side that came from the corner of the head into the manifold and then ran into one of the exhaust ports but on the vibrant header there was nothing there. It would actually block it off. I just figured it was for the egr valve?
Old May 5, 2009 | 07:32 PM
Smiles's Avatar
Did it give you any cels?
Old May 5, 2009 | 07:52 PM
cwlaser90's Avatar
i have one for an o2 sensor but im not sure if its because i didnt swap my sensors back or not. I used the sensors from the car i took the header off of and its probably posible one of them is bad. I highly doubt its header related tho.
Old May 5, 2009 | 08:21 PM
boost50psi's Avatar
im getting the same header for my 2.4 but one thing could you tell if it gave you more power and where did the power come in low or high RPM
Old May 5, 2009 | 08:37 PM
TurboTechRacing's Avatar
Bingo...
Here is how you find out if you do have SAI:
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/secondary-air-injection-late-production-2006-l61s-38488/
Also VERY few 2.4L have SAI... Many 2.2L do....
Also if you find this kit cheaper, somewhere else, let us know, send us a PM with the link...
Old May 6, 2009 | 12:50 AM
cwlaser90's Avatar
well its kinda hard to tell cause i installed my intake and header in the same day. When i drove it after the header installed it felt like a whole new car. Around 4.5K the engine starts to scream and pull all the way to redline. Very nice. I noticed it very well.
Old May 6, 2009 | 03:12 PM
Smiles's Avatar
hey cwlaser90 did you install just the header, or the header and dp?
Old May 6, 2009 | 03:19 PM
BMXIN749's Avatar
i installed mine last year...i have an 06 2.4 cobalt ss and it was bolt on....like an hour and a half long project...i think the hardest part is getting the stock downpipe and exhasut manifold apart....but once its off you fly right through...just make sure to pull the protective covering over the 02 sensor down a little dont just twist the whole thing vcuz it could cause damage to it....but yeah easy install just a ratchet and some muscle is all you need really
Old May 6, 2009 | 06:51 PM
cwlaser90's Avatar
Header and downpipe. Stock downpipe wont bolt up to the header.
Old May 7, 2009 | 06:28 AM
Smiles's Avatar
awsome! I'm going to order
Old May 18, 2009 | 10:56 PM
boost50psi's Avatar
have you had to do a E-test yet do they pass with the vibrant headers and down pipe on?
Old Jun 22, 2009 | 08:49 PM
DeViLzX's Avatar
With catless or with cat ?
Old Jun 23, 2009 | 12:52 PM
pat_07ss's Avatar
if yours is catless, it will throw a CEL no matter what
red9
Oct 4, 2017 02:23 AM
Northindy
Oct 31, 2015 01:35 PM
Barkleyj605
Oct 24, 2015 12:07 AM
patooyee
Oct 15, 2015 05:11 PM
