What is the 4t45e converter stall stock and what stall should I go for?
Old 05-11-2009, 07:18 PM
celicacobalt's Avatar
Question What is the 4t45e converter stall stock and what stall should I go for?
I'm getting my trans built by http://www.engineered.net/eplsd.htm and it should be here by the end of the week but I still need to know what kind of stall the stock converter is and what stall I should go for if not stock. As of the last time I raced the car I know it didnt go high enough for me to build boost at the line. I'm thinking it was stalled at 2100 or so. I want a slightly higher stall to maybe build a little bit of boost at the line but I'm most concerned with keeping it daily drivable and not a pain to go around town.
Anyone have some input? Need to know by wednesday. Thanks.
Old 05-11-2009, 07:36 PM
HunterKiller89's Avatar
stock power it stalls at maybe 2,200rpms. mine now stalls (or has a fuel cut actually...) at 2,900rpms. The stock converter is a good size IMO
Old 05-11-2009, 07:39 PM
riko540's Avatar
I've read that the stall for the stock converter is 2500 RPM. I'm personally think that 2500 RPM should be enough but we're talking about the stock converter which probably wasn't designed for hard launches and will reduce the life of it significantly.
Ah but what do I know my car is still completely stock performance wise.
Old 05-11-2009, 07:48 PM
yeah it might have been higher but i cant remember. all i know is it didnt go high enough for boost at all.
Old 05-11-2009, 08:06 PM
mmcgee123's Avatar
Find someone with the same auto slam on the break and gas w/e rpm its at is the stall
Old 05-11-2009, 09:53 PM
thats what i was hoping for someone on here to do for me.
Old 05-11-2009, 09:58 PM
riko540's Avatar
I'd do it but I have to do it at the track cause there are too many cops around here and I don't want a ticket for attempted street racing lol
Old 05-11-2009, 11:44 PM
do it in your driveway?
Old 05-12-2009, 12:05 AM
blackbolt89's Avatar
i hear ya man. cops are dicks in jersey.
Old 05-12-2009, 05:44 PM
wesg631's Avatar
mines stalls at about 2000
Old 05-12-2009, 06:20 PM
riko540's Avatar
Then my neighbors call the cops cause they can't stay out of other peoples business.
Old 05-12-2009, 11:39 PM
its not against the law to rev your engine to 2200rpms in your driveway...in fact, you can rev the **** out of it as much as you want as long as it isn't past 10pm i believ
Old 05-14-2009, 01:15 PM
Turbo06Sedan's Avatar
mine stalls right at 2k
I did this shortly after reading this.
Old 05-14-2009, 06:49 PM
I thought thats where mine was stalling at 2k. How are these people seeing 2800 stalls?
Old 05-14-2009, 09:40 PM
Not sure. Maybe different years = Different stalls.
I went and did it 4-5 times throughout the day. 2k each time.
However to you, id recommend at most a 3k stall. otherwise your car wont be very fun to drive just cruisin around.
Old 05-14-2009, 11:01 PM
I think im gonna stay stock, heard too many undesirable side effects of a bigger stall for a street car, Im sure it would be beneficial for a full race car but not sitting in traffic. Plus I already have traction problems at the line, cant imagine launching under boost making those any better ha ha.
Old 05-15-2009, 09:58 AM
a 3k would be adequate. anything higher is just stupid on a street car.
as for the launch under boost, your right. but thats nothin a set of radials/slicks wont fix
Old 05-15-2009, 12:08 PM
Maybe a 2500 would be good, I cant get a hold of the builder right now to see if I still have time to change my choice but either way a 2k will be fine if thats what it is, i'll think of it as launch control ha ha.
Old 05-15-2009, 12:39 PM
right. but who knows, they might be a 2xxx stall, but we're only seeing a 2k.
so your 2k might only be 1500....im just shootin for anything.
i've seen people buy 3500stalls, and they end up stalling at 3100...
regardless, good luck to you and thats pretty bitchin.
Old 05-15-2009, 07:29 PM
I talked to the builder today and he said that he believes the 2k stall is a tuning issue with the throttle not be 100% open when torque braking. He said possibly it could be only opening the throttle 40% and that could be causing the 2k stall. Gotta see if it can be tuned to stall higher.
Old 05-17-2009, 05:56 PM
ya, i would like to get a new TB...and get a ebrake that actually ******* works.
good luck with whatever you do, let me know.
Old 05-18-2009, 11:59 PM
going with a 2570 tq cnvtr so itll have a slight ammount more room. hopefully it works out well.
Old 05-19-2009, 09:54 AM
how much is all this runnin you?
Old 05-19-2009, 07:53 PM
3500 shipped. Why?
Old 05-20-2009, 12:22 AM
nhanson's Avatar
how can you tell where the stall RPM is?
Quick Reply: What is the 4t45e converter stall stock and what stall should I go for?
