what do i use to clean my Throttle body?
Old Mar 21, 2009 | 04:47 PM
rcmpayne's Avatar
Canada what do i use to clean my Throttle body?
GM told me my TB was dirty and wanted 99.99 to clean it, i think thats way to much, i took my intake off and it is very dirty. What can i get to clean it
Local shops are:
Canadian Tire
NAPA Auto Parts
Walmart
Old Mar 21, 2009 | 04:55 PM
Black SS/SC 06's Avatar
Throttle body cleaner
It should only be a few bucks at an autoparts store.
rcmpayne's Avatar
all i can find is carbarator cleaner???
Old Mar 21, 2009 | 04:58 PM
superbug's Avatar
All of those stores will carry some throttle body cleaner spay of one kind or another. For the most patr it's all the same. It's $8.99 a can at my Canadian Tire. Price may vary on the other side of the country.
Give the monkey at the Canadian Tire parts counter this product number 38-0781-2 and tell them to get it for you
Old Mar 21, 2009 | 04:59 PM
rcmpayne's Avatar
ok going now
Yea mine was like $3 or $4
Old Mar 21, 2009 | 05:00 PM
2007victoryred's Avatar
Wouldnt deep creep work
Old Mar 21, 2009 | 05:01 PM
superbug's Avatar
ah. I'd like to pay those American prices too LOL
Old Mar 21, 2009 | 06:18 PM
Red07SSNA's Avatar
I use electrical/brake cleaner (not the water solvent variety!)...leaves no residue. I remove the TB and clean it -- and do not spray around the throttle shaft into the bushings. When done cleaning I use some "Mothers" aluminum polish to make the inside look like glass.
Old Mar 21, 2009 | 06:33 PM
slobalt08's Avatar
I just took a paper towel and went around it a few times for mine. But it wasn't that dirty to begin with.
Old Mar 22, 2009 | 07:25 AM
rcmpayne's Avatar
ok all cleaned and all back to gether, the only issue now is the idle is high like 1500rpm. if i shift it in drive then back to park it goes to normal.
Old Mar 22, 2009 | 12:48 PM
superbug's Avatar
forget to connect a vacuum line?
Old Mar 22, 2009 | 01:10 PM
_UnLiMiTeD_'s Avatar
thats what it sounds like. Go double check them all, u will probably find one thats not on or its not on properly
Old Mar 22, 2009 | 01:15 PM
rcmpayne's Avatar
Everything is connected properly. I double checked. I just drove 150 km and its still doing the same thing.
So I just pulled over. Put the car in park and the idle went up to 1500. Put it in reverse and back to park. The rpm dropped down to about 900.
Old Mar 22, 2009 | 01:27 PM
Take the car to the dealer, dont tell them you cleaned it
Old Mar 22, 2009 | 01:34 PM
Red07SSNA's Avatar
The high idle makes no sense...did you remove your TB to clean it? If so, take a look at all the intake connections -- seals installed correctly? there are no vacuum lines you have to remove to take off the TB so that shouldn't be the problem. Considering that the idle settles down after tranny selection should indicate you didn't mess something up (gasket wise) otherwise it wouldn't correct itself. Have you performed an "erase" through the OBDII port to reset all the learn values? I would try that -- and check for any stored DTCs. Also check your electrical connector -- look at the pins carefully to make sure none are bent.
Old Mar 22, 2009 | 02:06 PM
rcmpayne's Avatar
The only thing I took off was the intake and the maf. I just checked the maf and its fine.
I can post a vid if it helkps any?
Old Mar 22, 2009 | 02:10 PM
Red07SSNA's Avatar
So you did not take off the TB or disconnect the wire connector...that leaves the MAF, Intake tube sealing, and the PCV tube. All those are sealed properly?
Did you spray into the TB while the engine was running or stopped? What did you use?
Old Mar 22, 2009 | 02:31 PM
rcmpayne's Avatar
I used the part number above. With the engine running, as I was spraying I had someone going back and forth gently on the gas pedal so it would not die out just as the instructions said.
My intake is custom and the maf sensor is in with sealent. That was done last night.
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
