what end link are the 2.4's getting..?
Old Jul 25, 2011 | 04:51 PM
CHEVRO_SS's Avatar
i heard moog is good...? part number? where can i get them?
Old Jul 25, 2011 | 05:00 PM
05blkrado's Avatar
I like moogs. I would say oreillys should have them
Old Jul 25, 2011 | 05:03 PM
CHEVRO_SS's Avatar
Moog K6698 these ones?
Old Jul 25, 2011 | 05:06 PM
05blkrado's Avatar
Those are showing for Control arm bushings
Old Jul 25, 2011 | 05:10 PM
05blkrado's Avatar
I can't find a pn for them
Old Jul 25, 2011 | 05:37 PM
noorj's Avatar
just got moogs a few weeks ago, love them. it was a bitch gettin my stock ones out tho. i ended up just taking the angle grinder to them
Old Jul 25, 2011 | 05:52 PM
outtamymind's Avatar
the 2.4 should use these ones K80252
Old Jul 26, 2011 | 01:06 AM
Dave7417's Avatar
if you are stock (ride height) FE3 suspension then use K80252 like 'outtamymind' said.
if you are lowered then use K750012
Old Jul 26, 2011 | 01:29 AM
hmmm i'm lowered on SSC springs and been using the k80252 with no problems. whats the difference with the K750012?
Old Jul 28, 2011 | 12:09 AM
CHEVRO_SS's Avatar
yes i wanna know too
Old Jul 28, 2011 | 09:35 AM
noorj's Avatar
The fe5 moog endlinks are the shorter ones designed for the fe5 sway bar
Old Jul 28, 2011 | 09:37 AM
so i'm gonna assume that the K750012 endlinks are for the FE5 suspension?
Old Jul 28, 2011 | 07:39 PM
Verbatim's Avatar
I have the pedders with sstc shocks and struts and I am using the FE5 endlinks.
While it may be harder to install them of you aren't dropped at all, I would go with the FE5 links anyways.
With the shorter links, you will be "loading" the swaybar a little more than stock and that should make the car feel a little tighter.
And with the trouble of taking the old ones off; I have always used a pair of vicegrips on the 'stud' where the boot is and hit the nut with a 3/8 impact in several short quick bursts.
Old Aug 4, 2011 | 10:38 PM
CordiaDOHC's Avatar
Honestly I advise all FE3 2.4s to just go ahead and order moog FE5 endlinks. Im on eibach pros which barely lower the car (more like eibach leveling kit) and I have moog FE5s. They work great they are greasable and are much stronger than the stock FE3s (which can be bent by hand!)
So stock ride height or lowered if your replacing them just get the moog FE5 pieces.
Solaris99
28
Mar 15, 2017 01:22 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
ThoR294
Sep 28, 2015 05:31 PM
