what gains can u get from injectors??
Old Dec 6, 2007 | 11:28 PM
TALON's Avatar
possibly hp gains??
Old Dec 6, 2007 | 11:29 PM
sick06cobalt's Avatar
none...
the injectors are only there to determine how rich or lean your running.... so say running stage 2 with stock injectors hmm may not be a good idea considering that youll be running really lean... or running a 2.7 with stage 2 injectors same thing.. or running a stock pully with 42 lbers in there youll run really rich....
Old Dec 6, 2007 | 11:31 PM
Raven SS's Avatar
Originally Posted by sick06cobalt
none...
something of that nature..but the tune actually decides the fuel the bigger injectors are just there to be able to if u want
Old Dec 6, 2007 | 11:32 PM
Tofu's Avatar
The only time you will "gain" power from bigger injectors is if you are running lean and are able to compensate by adding more fuel w/ the larger injectors via tuning it.
Old Dec 6, 2007 | 11:33 PM
TALON's Avatar
thanx guys...
i just saw 2.4 guys putting bigger injectors on their cars and i was wondering why...
but u answered my question
Old Dec 6, 2007 | 11:34 PM
lol i don tkonw why they would but oh well... its cool
Old Dec 6, 2007 | 11:36 PM
TALON's Avatar
i know this is off topic but i was looking in your garage and saw that you have tinted tail lights... have u ever gotten pulled over for those??
Old Dec 6, 2007 | 11:37 PM
XM15's Avatar
I think they (2.4s) are doing it because when they have full bolt ons and an aggressive tune, they are seeing a high IDC with the stock injectors.
Old Dec 6, 2007 | 11:39 PM
REDFOCZ's Avatar
The larger injectors are not need on the 2.4 period. Unless you have cams and headwork or some type of F/i, haveing larger injectors just gives you something else to put in you mod list.
Old Dec 6, 2007 | 11:59 PM
Omega_5's Avatar
... I think I understand where this is coming from...
Yes, the GM stage 1 for the LSJ is simply injectors and a tune... yes it gains power....
Why?
Because in this tune, the redline gets raised, releasing more power potential from the car.... the injectors are put in to accomidate the extra fuel needed at the higher engine speeds.
Old Dec 7, 2007 | 12:00 AM
lol... once... but didnt get a ticket... in fact the cop pulled me over to say they look good and that he just didnt want me to get rear ended.. thats all
Old Dec 7, 2007 | 01:07 AM
an0malous's Avatar
Injectors are a potential power mod.
like high octane fuel.
by themselves, they basically do nothing.
but when you tune to take advantage of those mods, power can be gained.
Old Dec 7, 2007 | 01:14 AM
REIGN SS's Avatar
Original Hayden Fanatic
I have "full bolt-ons" I/H/DP/EX and still only have an IDC of 92%
Old Dec 7, 2007 | 01:49 AM
REDFOCZ's Avatar
Tuen your COT off. and your IDC's will drop atleast 10%
or atleast retune the COT, because it commands a stupid rich AFR among the line of a 10.1 AFR
Old Dec 7, 2007 | 01:11 PM
WhiteSSBalt's Avatar
Not a Sebring
You'll only get "gains" from bigger injectors if the injectors you are running are insufficient for the power your making. Adding bigger injectors just allows your motor to create more power, but they dont make the power itself.
Old Dec 7, 2007 | 01:16 PM
SJSchafer's Avatar
One thing that does help, is that often when people put on bigger injectors, the injectors they put on are of a better quality, and a bit faster. This doesn't really raise hp, but does increase the overall performance.
Old Dec 8, 2007 | 12:29 AM
gocanucksgo's Avatar
so with my set-up...I/H/DP/E and soon to be HP tuned, i don't need bigger injectors? the stock ones are fine? I have a 2.4 G5 by the way...I've been told before they'd just be a waste with that set-up and if i was getting cams or headwork, then I'd need to get them.
Just wanna clarify...lol
Old Dec 8, 2007 | 12:35 AM
REDFOCZ's Avatar
Have your tuner log the car to check your IDC's, I have the same set up as you, and my IDC's are only 79% so depending on your tuner and what your IDC's are is when you make your choice.
Old Dec 8, 2007 | 12:37 AM
REIGN SS's Avatar
That is correct, you shouldn't need larger injectors, your tuner can tell you what your IDC is..
I'm not sure about the cams question, G5mike would be a good guy to answer that, he is/was one of the few 2.4 with cams
Old Dec 9, 2007 | 01:09 AM
cool...thanks guys. I'm not getting into cams or anything, so no need for them.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
yellow dragon
Sep 28, 2015 09:49 PM
