What injectors?
Old Aug 3, 2007 | 01:10 PM
soccer918843's Avatar
What injectors?
I just bought 07cobaltowners turbo kit and it comes witha special intake hat complete with a single 60lb-hr injector. But someone told me to use the 2.0 sc injectors what size are those?
Thanks
Old Aug 3, 2007 | 01:12 PM
BriantheLion26's Avatar
Thanks
Stock 2.0L injectors are 34#/hr.
Old Aug 3, 2007 | 01:17 PM
chevysalesman614's Avatar
is this an ls, or an ss n/a?
Old Aug 3, 2007 | 01:24 PM
cobi's Avatar
That 60# injector should be the fifth injector, if it came with the kit I'd use that one.
Old Aug 3, 2007 | 01:27 PM
then it should have a piggyback, right?
Old Aug 3, 2007 | 01:30 PM
cobi's Avatar
yup, sounds like the Alpine turbo kit
Old Aug 3, 2007 | 01:32 PM
Sw4y1313's Avatar
Just buy hptuners, keep the 5th injector in but dont have it hooked up(so you dont have boost leak). Buy some 32lb(stock lsj) injectors and tune with hptuners. If you plan on pushing more then the 7-8psi its set for, buy some 42lb'ers and throw them on. I believe that kit is non-intercooled right? So you dont really want to push anymore then 8-9psi. You should be fine with the 32lbers. Your IDC's may get a little high tho, so running 42lbers wouldnt hurt. Car should handle 9psi no problem =P
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
