What is the most bad a$$ combo of motor and tranny mounts that I can get?
Old Mar 3, 2008 | 06:21 PM
mkulrey13's Avatar
I have motor mounts and poly tranny mounts that are getting installed with my clutch next week, ill let ya know how they feel
Old Mar 3, 2008 | 08:43 PM
djt81185's Avatar
Originally Posted by celicacobalt
well, why else would my engine shake so hard sometimes even after its warmed up?
What do u mean its shaking? its doing so at idle? its doing it when revving it? The stock mounts are designed to keep vibrations from coming into the car...there for they isolate the motor from the body...meaning the motor has to move in its mounts to keep vibration from being felt in the car.
Mounts will reduce movement of the motor at idle and while revving but will increase the vibrations felt in the cab...a broke mount will make banging and clunking noises under accel and decel...movement at idle and when revving without moving does not equal broke mounts.
Old Mar 4, 2008 | 09:40 AM
celicacobalt's Avatar
well, it just seemed to move more than normally. ive never had broke mounts before so i dont know the effects. I would benefit from new tranny and upper engine mount either way though.
On my stock mounts i get alot of cabin vibes, if i look at my passenger seatbelt when sitting idle, it hangs there and shakes very bad.
Old Mar 4, 2008 | 09:43 AM
steddy2112's Avatar
On the manual...they are seriously the best mod I have done to date.
******* amazing.
Seriously...get them...it makes the car feel alive.
They are fine.
BTW if you get the Poly inserts they would work(I dunno if anyone has mentioned that yet)
And the upper mount, ****...it is the same on all of em.
The worst vibe you get is at startup, and from a dead stop, that is IT...anyone who complains about vibes needs to blow the sand dune out of their vagina...seriously
Old Mar 4, 2008 | 09:46 AM
RuSSo-29's Avatar
Ttr Ftw
Old Mar 4, 2008 | 09:53 AM
like i said, on stock mounts i get bad vibes already, maybe these will be less lol
Old Mar 4, 2008 | 10:05 AM
djt81185's Avatar
It will not vibrate less...it will vibrate more...my car with neutrals, solid metal upper, and intense trans mounts will make u think ur riding in electric buzzer...on the bright side...girls love it
i mean EVERYTHING in the car vibrates and rattles...granted i probably have the most extreme mount setup of anyone and neutrals
Old Mar 4, 2008 | 10:16 AM
steddy2112's Avatar
Intense trans mounts are the same thing as a poly insert on the stock mounts.
You vibe more because of the neutral balance shaft deletes
Old Mar 4, 2008 | 10:36 AM
yeah these cars after you put some more power in them shake like hell.
Old Mar 4, 2008 | 08:39 PM
spike's Avatar
hahahaha............................ i love the fact that this make not much since........... the mounts r the biggest reason for this.............. go grab something that shakes with a piece of foam in your hand(stock mount)......... not that bad of vibe's............. now grab it with your hand(poly mounts) u feal the vibes more..........
Old Mar 4, 2008 | 08:41 PM
  #36
steddy2112's Avatar
I meant vibes more than me.
Diiiir.
Damn everyone on this site is a ******* professional...no **** the poly mounts make every vibe more...but I don't vibe no where like he describes...
Old Mar 6, 2008 | 08:59 AM
  #37
so looks like i can only do the tranny mounts right now until ttr sorts out the upper engine mount issue.
Old Mar 6, 2008 | 09:16 AM
  #38
TurboTechRacing's Avatar
Automatics use a different style upper mount, we will be designing and manufacturing one, as soon as we can get the dimensional specs of the stock one
Old Mar 6, 2008 | 09:40 AM
  #39
sounds good, ill be buying when it comes out. us autos on here are going pretty fast so we need this support.
Oct 13, 2015 09:32 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
