When the 2.4 gets sluggish
Any ideas on how to remove some sluggery? Plugs have 15K on them. AEM intake and Maglaflow cut n weld muffler. Any economical suggestions? Clean MAF and throttle body? Fuel injectors? Better plugs? Fuel treatments? I have 147K on motor. Driver mod?
Different heat range plugs won't make a difference on a N/A. As long as they aren't fouled. Clean MAF and TB definitely good to get into the habit of. Super easy. I run seafoam through my tank once every oil change or two, but also use quality gas. Can still hang with new V6 Camaros.
http://www.stevesnovasite.com/forums...d.php?t=348033
Here is what it did for my pistons in my project car. Just pour it in your tank right before a fill up.
That's out of the car and in its concentrated form with scrubbing action, you can do that with anything. lol Seafoam in the gas tank really doesn't do anything, pale oil and naphtha when burned in the combustion chamber don't do **** to clean the cylinders. If your concerned about your fueling system being dirty, send the injectors out to be sonic cleaned. It's $16 dollars an injector and keep a clean fuel filter. You will actually cause more problems then you solve by throwing additives in the gas tank, especially anything oil or kerosene based, which slows combustion time. I've done dozens of repairs where the injectors were gummed up or the plugs severely fouled from these damn cheap ass additives. The only additive worth a damn is the redline fuel injector cleaner which is comprised mostly of PolyEther Amine, a very strong detergent used in chevron techron.
I'd always had good luck with it in my Nova days. I'll probably continue to use it. Took the Nova with its burnt or coked valve or whatever it was, and made it sound new again. But I suppose it was also concentrated then. Quick google search shows the Shell fuel I always use contains PEA also. Guess I'm fine there. I'm antsy to pull this motor apart to see how clean or dirty it is, if only it wasn't my daily.
