Where is the IAT sensor??
Where is the IAT sensor on the 2.4? Doing a sc swap and can't find it for the life of me. It's the last piece to the puzzle
Not exactly. The how-to we had said the IAT was it's own sensor. Some research showed some early LE5's had a sperate one and rest don't. (?)
Anyway, got it up and running. Now to fix his vac leaks and primary O2 sensor
I finally have a MAP w/IAT in my possession >> Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT
If as posted here 2 wires are tan and tan/white, can I assume one is a 5v and the other the NTC? New map sensor only has 1 5v power source, should i split it or what?
I kept the 2 BAR as a MAP sensor and split power and ground from it to the 3BAR and cut the IAT NTC off the MAF and attached it to the 3BAR IAT sensor. So now I have my old 2BAR reading MAP and IATs being read post boost off the 3BAR . Reason I did this is I wasn't sure what to do with the IAT reference and also didn't know if E67s could read 3BAR properly.
Knightwolf
09-12-2015 11:02 AM
