Where is the IAT sensor??
Old May 30, 2009 | 05:08 PM
WickedSS2005's Avatar
Where is the IAT sensor on the 2.4? Doing a sc swap and can't find it for the life of me. It's the last piece to the puzzle
Old May 30, 2009 | 05:36 PM
Rodimus_Prime's Avatar
is it part of the map sensor like the LSJ
Old May 30, 2009 | 07:10 PM
BennyHHR's Avatar
Don't listen to Rodimus...
It's part of the MAF sensor on the intake. Wires are tan/tan&white on one end.
Old May 30, 2009 | 07:13 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
WRONG!
RIGHT!
IAT1 comes from MAF... IAT2 comes from MAP.
Old May 30, 2009 | 07:23 PM
Deathscythe's Avatar
go to sleep grandpa!
Old May 31, 2009 | 12:19 AM
i couldnt find any high res shots of the engine
Old May 31, 2009 | 12:33 AM
WSFrazier's Avatar
Same place it is on the LSJ?
Old May 31, 2009 | 04:39 AM
Not exactly. The how-to we had said the IAT was it's own sensor. Some research showed some early LE5's had a sperate one and rest don't. (?)
Anyway, got it up and running. Now to fix his vac leaks and primary O2 sensor
Old May 31, 2009 | 05:04 AM
HunterKiller89's Avatar
all L61/LE5 ecotecs to the best of my knowledge have the IAT integrated int the MAF sensor. Im pretty certain this is the case with all Cobalt ecotecs at least (even the LSJ's IAT1 is in the MAF)
Old Jun 28, 2011 | 08:29 PM
OttawaMark's Avatar
I finally have a MAP w/IAT in my possession >> Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT
If as posted here 2 wires are tan and tan/white, can I assume one is a 5v and the other the NTC? New map sensor only has 1 5v power source, should i split it or what?
Old Jul 3, 2011 | 06:11 PM
OttawaMark's Avatar
I kept the 2 BAR as a MAP sensor and split power and ground from it to the 3BAR and cut the IAT NTC off the MAF and attached it to the 3BAR IAT sensor. So now I have my old 2BAR reading MAP and IATs being read post boost off the 3BAR . Reason I did this is I wasn't sure what to do with the IAT reference and also didn't know if E67s could read 3BAR properly.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
