Who makes cams for the LE5
I can barely afford my Cobalt as it is. I dont need a $5,000 engine too, lol. Whenever my stock engine goes and I HAVE to get a new engine, then i'll look into the JBP blocks.
no ****
but then again you might not know how to drive.. i tried to get your ass out to the tracks alot of time but a 45 min drive is too far for you
.. some people drive 2-3 hours to a track.. but anyways i ran a 15.2 with intake and a muffler lol.. you give me 25 more whp and ill be 14.5ish
btw, you still going to the meet today?
Its at the town center in Frederick MD. Adress is on the 1st page. At least come by for a little bit if nothing else.
GM LE5 - LNF CAMS SWAP http://tunersource.gmblogs.com/Racer...FO-SHEET-2.pdf
If they can be swapped, what kind of difference do you think it would make?
....i cant consider nos as naturally aspirated....
So when people say "I ran a mid 14 with a X Shot of NOS...Naturally Aspirated"...i find it false due to NOS being considered Forced Induction
Quoted Directly from the tunersource blog under 2.4L:
The LE5 engine has variable valve timing and, therefore, has cam phasers.
Not compatible with the GM Performance Parts adjustable cam gears.
Both intake and exhaust cams have wheel-style cam locators.
Intake and exhaust cams are the same casting with different profiles and slightly different locations of oil sealing rings.
Intake and exhaust cam castings are the same casting as the LNF exhaust cam casting.
Cannot be replaced by the GM Performance Parts cam set or any aftermarket cam set.
Last edited by Turbo06Sedan; Dec 5, 2008 at 07:45 AM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
