would i need a tune?
im not sure on the whole tunning deal.
my modds are gmpp intake
gmpp manifold
gmpp cat-back perfromance
i have an auto, and its a 2.4.
so now that we know that, should i get a tune? would it even be worth it? how and where would i go to get it done.
gmpp manifold
well not really you wouldnt im running the same thing. then had a tune cuz i got bigger injectors. if you do get a tune for those then it would be because the 02s or reading more airflow in the exhaust and there trippin the cel or code or whatever it is. then yes go for it. but dont spend 400$ on a tune for just those. get injectors to then. the stock 34# from the 2.0 and the harness from a 2004 cavilear from gmpartsdirect.com well thats all i think.
ryan.
ryan.
yes you should always tune your car after getting it modded to ensure the best performance out of the mods... and if you can find someone with HP you can get your car tuned for about 150$ or so. the car runs really rich stock so modding it just throws the AFR even more outta wack. and stock the injector duty cycles run at about 99% and a 10.9 AFR stock... after a tune the IDC dropped to 79% and a 12.9 AFR at redline...
there was also a full bolt on 2.4 and his IDC's were 81% at the top of third gear with this setup. after tune... and those aren't even aggressive tunes they were just tunning for IDC and AFR basically
just get it tuned you'll see better power and better MPG more than likely, yes it's better to get the larger injectors but it's not necessary.
afr is air fuel ratio, IDC is injector duty cycle and it's % that the injector is open and giving fuel... at about 100% they can seize and then they stay constantly open and then... BOOMMMMM sorry for not clarifying as much as I thought I did...
regardless you sould always tune whenever you put a mod on your car to get the full gains out of the mod.. you ever wonder why compainies say you'll get X HP from their mod and you only get like 3/4 of that? more than likely they've tuned for it to make it run better.. why do you think a full bolt on 2.4 gain so much from a tune? you're optimizing your cars computer.. and thats always a good thing
on a side note... WOOOOT 300 posts
damn you redfocz haha you made me waste my 300th post on something you already typed haha
Last edited by elecblue06; Jun 18, 2007 at 11:29 AM. Reason: Automerged Doublepost
o well i needed that guys, im goin to north dallas now to get it dynod, they dude said $60 for 3 pulls, i guess thats good, atleast a start on what i can work on and what i have now,
later
later
I have full bolt-ons, including a cat-less downpipe, which threw my CEL.........and kept it on for good until I get tuning. To be honest, the car kinda runs like crap w/ my setup. Idle's a tad rough, hesitates some under WOT.........really needs tuning badly. But I have a bit more aggressive setup than the GMPP setup, so you might be alright. But finding tuning for the '07 LE5's is proving to be a b***h for me........so good luck. Im on constant "hold" essential from the only HP Tuner's dealer/tuner around me (Pro Motion Tuning), and several members on the forum have offered help but never respond in time to make anything happen. I'll get tuning eventually........
injectors would be a good idea. i hear from jackalope, that the 2.4 injectors go static once you do minor mods.
I'm looking right at what you need
You could however get a retune for the sake of your Automatic and turn that thing into a gear shifting machine.
