ZZP Auto Tranny is now here!
Old Dec 10, 2011 | 11:49 AM
OttawaMark's Avatar
ZZPerformance - 4T45E Transmission #
Standard to ALL ZZP transaxles are:
* All new Raybestos clutches
* New solenoids as needed
* New filter
* New sleeves, bushings, bearings and seals
* New bands
* New Borg Warner HV-093 chains
* Upgraded input speed reluctor wheel
* New valve body on shipped transmissions
* Differential gears and pinion shaft checked for wear
* Damaged or worn parts are replaced (bad differentials, or damage to the casing will be billed separately)
* Custom shift kit
* Plastic accumulators replaced with custom aluminum pieces
* Forward bands replaced with high energy green bands
* Hardened 4th clutch shaft
* Steel channel plate gasket
* Upgraded TCC apply valve
* GM DEXRON VI transmission fluid
Building and assembly is done with many proprietary techniques. This makes for very quick shift times, long clutch life, and higher HP capability than any stock transmission. /
Under 2k with the 245mm TC, not a bad deal even if no LSD is offered. When I buy, and I will...I'll see about sending them the EP LSD in place of the stocker.
Old Dec 10, 2011 | 12:02 PM
Mindrot's Avatar
They also offer a high stall. I'm getting that trans in March with a 3500 stall
Old Dec 10, 2011 | 12:03 PM
nhanson's Avatar
are you even close to wrecking your stock one?
Old Dec 10, 2011 | 12:06 PM
Mindrot's Avatar
I'm not even enjoying the life of forced induction yet and my trans is slipping already. 104k miles doesn't help I'm sure lol. 2/3 of its life is on a tune.
Old Dec 10, 2011 | 12:08 PM
08CobaltLT1's Avatar
nice, also nhanson how you like your ZZP header/DP ? im looking at purchasing that
Old Dec 10, 2011 | 12:24 PM
nhanson's Avatar
its great...good quality...no problems
Old Dec 10, 2011 | 12:28 PM
giggity! cant wait to start my build
Old Dec 11, 2011 | 04:54 AM
-TurboSS-'s Avatar
No transbrake option?
Old Dec 11, 2011 | 03:26 PM
nhanson's Avatar
its called the regular brake.
Old Dec 11, 2011 | 04:27 PM
-TurboSS-'s Avatar
It's for racing, but I guess it is kind of redundant with launch control. I'm assuming the 2.4 has lc? I don't have an auto.
Old Dec 12, 2011 | 09:59 PM
nhanson's Avatar
no it does not
Old Dec 12, 2011 | 10:34 PM
PsychoCam's Avatar
i cant even imagine all of the other parts needed to convert a manual to an auto
Old Dec 12, 2011 | 10:36 PM
OrlandoSS's Avatar
Thats awesome
Old Dec 13, 2011 | 07:51 PM
Mindrot's Avatar
That's what a high stall convertor is for. Which is why they offer a wide range for stall.
Old Dec 15, 2011 | 02:01 AM
-TurboSS-'s Avatar
You need a transbrake if you want to stall and launch at that exact rpm.
Old Dec 15, 2011 | 02:07 AM
Tundraboarder666's Avatar
interesting... too bad they're too late in offering this, I went with IPT instead because of the un-sureness and lack of response time from the ZZP team...
Old Dec 21, 2011 | 01:57 AM
Dragonsfire12345's Avatar
I've been debating on getting the DIY rebuild kit from IPT. This year is the year I rebuild my transmission. My goal for the car 400whp, and I don't think a stock 4t45e will take the beating.
Old Dec 21, 2011 | 12:33 PM
I can tell you that it wont, ask me how I know... lol
And you're gonna need more than just the rebuild kit... You have to actually ship your tranny to them and they do the actual build on it so that your tranny will survive... They modify quite a bit when they do it and include a 12,000 mile, 1 year warranty. No warranty just for the rebuild parts.
Old Dec 21, 2011 | 10:32 PM
thats what I figure
Old Jan 3, 2012 | 01:21 PM
bbowman2002's Avatar
Is this a replacement for a 2006 2.4l auto? Sorry just want to make sure, dont know the tranny # that is in my car stock...
Old Jan 3, 2012 | 01:38 PM
Mindrot's Avatar
Doesn't matter what year. If its an auto then its a 4t45 and yes this is the replacement.
Old Jan 3, 2012 | 01:42 PM
Thanks for the help... Dont know if I need a new one but shure would like an upgrade...
bigdeertz
Nov 17, 2016 09:41 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 28, 2015 01:31 PM
