ZZP Long tube header package
Old Apr 5, 2011 | 02:50 PM
  #51
RooTBeeR's Avatar
Originally Posted by GRok25
I dont have a stock exaust i have a 2.5" corsa catback
the corsa touring sounds sex
So unless some one can post a link for a 2.5" header/DP combo than I have to firsr make a decision between
2.5"
Cobalt & Ion ---> ZZ Performance
or 3"
after that what header should i use???
I AM NOT GOING TURBO OR SUPERCHARGED
i would say zzp longtube with 2.5" bolt in to keep velocity
Old Apr 5, 2011 | 02:53 PM
  #52
Mr.N00bLaR's Avatar
They dont make the longtube header in 2.5"
If you want they will make it, I have a 2.5 lth bolt in option.
Old Apr 5, 2011 | 02:59 PM
  #53
GRok25's Avatar
i think the primaries in the header will be too wide also. is there someone from zzp that i can speak with.
Old Apr 5, 2011 | 03:01 PM
  #54
GRok25's Avatar
isnt that only for the exit? is it ok for the rest of the piping to be 3"?
Old Apr 5, 2011 | 03:22 PM
  #55
RooTBeeR's Avatar
https://www.cobaltss.net/forums/zz-p...eaders-226826/
PM Zooomer
i know they did a 1-5/8" primary version before, that what maven is running
Old Apr 5, 2011 | 03:25 PM
  #56
GRok25's Avatar
Thank you
Old Apr 5, 2011 | 03:48 PM
  #57
CordiaDOHC's Avatar
PM Zooomer
I will stick to the larger primaries. I had their mid length on my 2.4 with the larger primaries and lowend tq was still enough to spin the tires for a good 5 ft with an auto. And it pulled hard uptop.
Old Apr 5, 2011 | 04:09 PM
  #58
GRok25's Avatar
link for the midlength???
cant find it on zzp's site
Old Apr 5, 2011 | 04:36 PM
  #59
CordiaDOHC's Avatar
Honestly just stick with the longtube. The midlength performed well but they are prone to leaks. Was just saying I dont believe going down in primary size is needed with the 2.4
Maven also ran the smaller primaries on a 2.2 L61 engine. Not the larger 2.4 LE5.
edit: actually it looks like zzp no longer makes the mid length
Old Apr 5, 2011 | 04:39 PM
  #60
GRok25's Avatar
what is the stock primary size?
the longtube is 1.75 and the mid is 1.50 right?
Old Apr 5, 2011 | 04:41 PM
  #61
CordiaDOHC's Avatar
Not sure on stock size. But im running a shorty right now and even it registered on the butt dyno as making a bit more power.
But the long tube is 1 3/4 and the mid length was available as 1 5/8 and 1 3/4 as well I think.
Old Jun 13, 2013 | 07:36 PM
  #62
oscarb24's Avatar
So would of been a better choice for the ZZP Long Tube Header Package the Off Road 2.5,3" catback or the one with Cat 2.5 3"?
HEATON
Oct 16, 2015 07:21 PM
z28addiction
Sep 28, 2015 12:03 AM
ashalle2
Sep 27, 2015 03:28 PM
