ZZP Midlength Check Engine???
i am looking to buy the zzp midlength header/dp combo. i will get it with the high flow magnaflow cat and the 1/2" primaries. will this throw on my check engine light?
u should be fine. the car may throw a code from not being used to the new air flow. but i didnt have a problem with my full exhaust. what i did have a problem with was my cai. it threw a code. but its the same basis. just have someone with a code reader delete the code if it does and then yes u will pass emmissions. its catted.. ha
my neighbor has a repair shop so clearing the code is no problem but if he clears it will it be off for good or will it light back up after x amount of miles
can you give me a link for that
and here. http://www.aeroforcetech.com/Redline_Cobalt_tech.html
i just didnt want the light on all of the time because then if something actualy goes wrong with the car than i wouldnt know because the light is already on lol.
but if it is constantly on or comes on frequently than is there something to do like piut a new sensor in???
ha i promise it wont come on many times if at all.
It will come on since the rear/downflow (or w/e it's called) o2 sensor is before the cat on the midlenght zzp header. As far as the car is concerned your basically running catless and it the cel/mil will turn on. My car is always rocking the cel from my midlenght zzp header... I'm going to buy a defouler real quick tho
http://www.modern performance.com/vibrant-oxygen-sensor-defouler-p-2094.html
Take the space out from modern performance to make the link work. But it basically extends your o2 sensor out of the pipe so it doesn't get accurate readings and won't throw cel's
yes you will most likely get a cel. you can get a defouler or get the rear 02 sensor tuned out by either hpt or trifecta then it'll never come back.
which defouler is better???
Vibrant Oxygen Sensor Defouler - Universal Exhaust Items
or
Vibrant Tunable Oxygen Sensor Defouler Kit - Universal Exhaust Items
or
p0420 code pops up 99% of the time someone switches out the dp. it's caused by the "high flow" cat (or no cat in some dp's) and means absolutely nothing performance wise, it just trips the CEL.
/thead.
