2.0 LSJ Swap into NA SS simple question!!
Old Aug 17, 2013 | 09:46 PM
codygetson's Avatar
I have a 2007 SS NA I used to have a 06 SC but bought it for resale and loved it the couple times I did drive it, my LE5 has 306km on it and first gear synchro is fair as well I was thinking about a LSj swap, I buy from salvage auctions quite oftentimes question is if I buy a whole SC car can I just drop the cradle engine trans wiring harness PCM and fuse block and put it right back up into the NA car in the reverse process and swap Is done? I have changed and engine in one of these before the LSJ was bad in the car I had bought
Old Aug 17, 2013 | 11:03 PM
mrbelvedere's Avatar
you ill have to rewire the entire car
Old Aug 17, 2013 | 11:06 PM
Probably easier to rebuild the 2.4l engine and add the blower to the 2.4
Old Aug 17, 2013 | 11:56 PM
redcobalt07's Avatar
the transmissions won't swap
Old Aug 18, 2013 | 01:08 AM
Tjolley's Avatar
So y do u want to do this. The le5 is a better starting point for a mild build.
Old Aug 18, 2013 | 01:12 AM
codygetson's Avatar
I can't repin the connectors if there's any differences? I want to do this because it seemed like the simplest way, it would be easier for me to find. Whole car than to piece together the whole swap and I don't feel like rebuilding the engine in my 4 cylinder beater car
Old Aug 18, 2013 | 01:14 AM
Tjolley's Avatar
The engine isnt hard to rebuild. It will be cheaper and way easier to do than to put a lsj in the car.
Old Aug 18, 2013 | 01:19 AM
codygetson's Avatar
If I drop everything in the engine bay invluding cradle from the LSJ car and put it into the LE5 the only thing I have to worry about Is the wiring going into the car is It not? If I got a wrecked LSJ car for say 1000 dollars is that not a cheaper route
Old Aug 18, 2013 | 08:53 AM
post this in the advanced performance section
Old Aug 18, 2013 | 11:09 AM
pjk91's Avatar
SC the le5. Much simpler.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
