What other cars can you swap an LNF into?
Reason I ask is because I found a cheap used LNF turbo motor from a trashed cobalt in a junkyard, I also have an old 96 thunderbird with a very terrible 4.6 ford motor in it. I'm half tempted to get this LNF motor and attempt to drop it into this thunderbird. Thoughts? Possible? Convert the LNF to run a rwd car?
There is somebody out there that successfully put one in a third gen camaro. With time and money anything is possible.
http://www.thirdgen.org/techboard/en...4-3rd-gen.html
My Solstice has an LNF
The problem with LNF swaps is that you need the whole wiring harness and pcm. The LNF is one of the most computer run motors out there, so getting everything with the motor is critical. If you do it right, I'm sure it would be awesome. I know there is a sand-rail out in Cali that has an LNF swapped in it, and I thought there was an Ariel Atom with an LNF swap too.
Turbo Johnny
Feb 21, 2019 09:41 AM
Highgross89
20
Sep 11, 2015 03:24 PM
jcalvin1126
Sep 11, 2015 10:24 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
