2 bar MAP for 2.2l?
Old Nov 9, 2011 | 03:14 PM
rcarr0327's Avatar
2 bar MAP for 2.2l?
so ive been looking around trying to find a 2 bar map for the 2.2l but can only find one for the 2.4 LE5 (- 2.4 LE5 MAP Sensor #10-01-00786) has anyone used this for the 2.2l or is there another sensor i should look at? thanks guys!
Old Nov 9, 2011 | 03:19 PM
1LowLS's Avatar
I'm actually gonna be running the stock LSJ map sensor for mine.Already have the sensor,just need the pigtail,then im gonna wire it up to read iat2's as well.I also found out that our stock MAP sensors only read up to 2.7 PSI max.I have the "Torque" app on my phone and used my buddys bluetooth obd2 plug and looked at all the PID's and map pressure only read 2.7 psi.
Old Nov 9, 2011 | 10:25 PM
rcarr0327's Avatar
ok i understood the logic of what ur saying just dont know specifcs about how our MAP reads. when you do this are you gonna do a how to? PM when u get this done
Old Nov 15, 2011 | 12:20 AM
Leafydialupking's Avatar
The standard GM latemodel 2 bar map will go in the hole in the stock manifold on the 2.2 and plug right into the stock connector. It looks like this.
Home ť Shop ť Sensors ť Pressure Sensors ť 2 Bar Late Model GM Style Map Sensor
This isnt the best price but it give you all the data you could ever want about the sensor.
Old Nov 15, 2011 | 12:31 AM
1LowLS's Avatar
Do you know what vehicle would use this facotry if any?Or is this aftermarket only?
Old Nov 15, 2011 | 12:32 AM
Not off the top of my head. I bet google knows.
Old Nov 15, 2011 | 12:34 AM
drumrush's Avatar
so the 2.4 map is different than the 2.2 map?
Old Nov 15, 2011 | 12:35 AM
1LowLS's Avatar
yes^^I have the 2.4 map plugging the map hole on the SC lol
Old Nov 15, 2011 | 12:36 AM
drumrush's Avatar
thats the one i just modified lol, i thought they were the same. whats the difference?
Old Nov 15, 2011 | 12:37 AM
Then it is the same as the 2.2 map. The 2.2 map the 2.4 map and the map that goes in the hole of the supercharger right behind the TB are all the same form factor (aka size and shape).
The LSJ map for the blower manifold is different.
Oh and supposedly the map that goe sin the blower is actually a 2 bar map. But I have never gotten a confirmation on that.
Old Nov 15, 2011 | 12:41 AM
1LowLS's Avatar
in 2007 they changed.I tried putting the stock 2.2 map on top of the blower and no go.2007 up stock 2.2 map is the same diameter and the lsj.I just remembered the 2.4 map I have is 2006,so im assuming they changed on the LE5 as well.
Old Nov 15, 2011 | 12:42 AM
rcarr0327's Avatar
so i can get the 2.4 2 bar map from zzp and hook it up to my charge piping?
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
SSLOW06
Oct 1, 2015 07:21 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
