300 HP NA build
Old Mar 14, 2010 | 09:26 PM
  #51
fakameanrepresent's Avatar
itb, that is all.
Old Mar 14, 2010 | 10:15 PM
  #52
slowswap's Avatar
Originally Posted by fakameanrepresent
itb, that is all.
You bumped a super old thread to add a piece of info that's been said?
Old Mar 16, 2010 | 12:39 AM
  #53
1Bad67's Avatar
At least someone else is interested. I haven't done much more. Work hasn't been that busy latley, so I haven't had enough spare $$$ to buy the pistons & cams. I have been piddling with small parts like welding fittings onto the valve cover, and machining unused bits off the head. As the racing season gets underway, I'll get back to working on the motor. First things first though, I tore the car up a bit at the last race last year, and need to repair it first.
Eric
Old Mar 28, 2010 | 01:59 PM
  #54
ITB's, that would be such a sick mod for any N/A.
Old Mar 31, 2010 | 09:24 AM
  #55
ericss's Avatar
You will easily make 300+whp with the parts you plan on running GLWTB
Old Mar 31, 2010 | 09:27 AM
  #56
ml2242's Avatar
Fred Jr. of SMG Autosports has a drag Cavi with the 2.2 and hes pushin 300+ hes a supporting vendor on here i'd hit him up and ask about his N/A race car build
Old Mar 31, 2010 | 12:46 PM
  #57
1Bad67's Avatar
Cool.. I'll look him up. I just need to some OT so I can buy the pistons & get the head ported.
Old Mar 31, 2010 | 08:56 PM
  #58
NWAE Cobalt's Avatar
Pistons arent too much, who are you going through?
im working towards this myself but the rest of the build had to be put on hold due to some financial and family dynamics....
so far im just around 200whp with mostly stock internals (78lb valve springs, stg 2 cams, & shaved head .020")...so its DEF possible
i plan on getting 11.5:1 or 12:1 comp ratio pistons, bore it out a lil, port and polish cyl head w/ oversized valves, and then add the supporting stuff (balance rotating assembly, remove balance shafts, rods, etc) and hoping to hit 250-275 whp
def possible, just time and money
Old Apr 1, 2010 | 11:31 AM
  #59
1Bad67's Avatar
I'm running Alcohol, so I want at least 14.5:1 JE will custom make them for $800. Which seems reasonable to me. They will take a mold from my combustion chamber, and machine the dome to match. Some of the guys on here don't like JE, but since they are the ones GM and Roush are using they will proably work for me.
Keep us posted on how yours goes.
Old Apr 1, 2010 | 12:26 PM
  #60
383_Stroker's Avatar
JE makes some damn good pistons..
Old Apr 1, 2010 | 06:44 PM
  #61
not a prob, will do
i talked to wiesco while at sema last year and he quoted me 650ish with wrist pins and rings coated.
Old Apr 9, 2010 | 11:35 AM
  #62
alanoo's Avatar
Best piston for an N/A will be an X forging style
Try to talk to CP Pistons, I know they provided some pistons to GM Racing and do quite a lot of X forgings (aka 'boxed and shaped').
JE are fine too, but often makes slightly heavier pistons than others.
Old Apr 9, 2010 | 11:54 AM
  #63
ralliartist's Avatar
I picked up my wisecos for 525 shipped with rings and wrist pins.
Old Apr 9, 2010 | 12:10 PM
  #64
1Bad67's Avatar
alanoo, I'll call CP today, thanks.
ralliartist, what was the compression ratio for the ones you got?
Old Apr 9, 2010 | 12:24 PM
  #65
alanoo's Avatar
Let us know what CP will tell you, I'll be very interested if they can do X forgings for our engines
Old Apr 9, 2010 | 12:36 PM
  #66
I just got stock bore (86mm) and stock compression (9.5:1). But it wouldn't have cost me any extra to get them bigger or higher compression.
Old Apr 9, 2010 | 01:02 PM
  #67
alanoo's Avatar
9.5 so I guess it must be for a boosted engine,
Full round designs for this application at Wiseco, and this is much simplier than a good N/A design
Old Apr 9, 2010 | 01:34 PM
  #68
simplier? what? you do realize it wouldn't have cost any extra to make it higher compression. I even get pretty big valve reliefs in case I ever find a cam that's worth a ****.
Old Apr 9, 2010 | 03:38 PM
  #69
alanoo's Avatar
Full round designs are by far simplier than slipper ones
Wiseco's low comp are used to be full rounds, high comps are slipper ones
It's not inferior, it's just not for the same application
slipper :
classic full round :
X-forging / boxed and shaped :
Old Apr 9, 2010 | 04:55 PM
  #70
I should have took pics of the underside of mine. All i got is pics of the top. I'll be sure to grab some pics of the underside when I get back to the states.
In the meantime.....
Old Apr 9, 2010 | 11:59 PM
  #71
JapEatr's Avatar
South Central *********
if were posting pistons...then Diamond 9.5:1 coated with Pauter Rods machined to fit the larger wrist pin
Those Xforged pistons tha allanoo posted are what is in the LNF engine...nice design
Old Apr 10, 2010 | 08:43 AM
  #72
alanoo's Avatar
Cool slipper design, already much better than a full round one
Old Apr 10, 2010 | 09:15 AM
  #73
drewbroo's Avatar
Its doable. But a cosworth YDX is a drop in 2.3L (Mazda MZR motor.)
http://www.jensenmotorsport.com/car/engine.htm
Also are you planning on doing an ITB setup?
Old Apr 10, 2010 | 12:22 PM
  #74
yea, but there was one downside to them that I got around fairly easy since I have such an awesome machinest. The oil squirters had to be machined a lot because the new pistons had clearance issues with them. But like I said, my machinest is bad ass and he made it work.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
