CR difference between .040 and .027" head gasket
Old Dec 2, 2008 | 06:34 PM
Ryze's Avatar
I know that the LSJ stock head gasket is .027" thick when compressed, but whats the compression difference if I go to a .040" thickness gasket used on the L61 (2.2)
The only reason why I ask is I want to know how much difference there is, because I'm building a L61/LSJ and I need to know which compression pistons to get within the static CR I want to be in
Old Dec 2, 2008 | 06:39 PM
o3nisoaso3's Avatar
dont quote me on this because i have no math in front of me to go by but if should put you around 9.0 (if youre using stock 9.5:1 pistons on the lsj) i will find some calculations later n give you a better number but you may need a compression test for an x in the math... im not sure
Old Dec 8, 2008 | 12:21 PM
alanoo's Avatar
~0.3 point in CR
I think the head cc are different themselves too between L61 and LSJ, so might be a bit more difficult to get a conclusion
Old Dec 8, 2008 | 10:17 PM
o3nisoaso3's Avatar
Originally Posted by alanoo
~0.3 point in CR
i was giving a rough estimate of .5 but you seem a bit closer than i do but still like we both say, lsj to l61 comparison n sizes to be used in equations is needed for an answer
Old Dec 13, 2008 | 06:21 AM
ReckleSS's Avatar
Go to this page and use the compression ratio calculator.....just change the gasket thickness to see the results:
http://www.swansonperformance.com/calculator.html
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
