Dual Pass intercooler
Old Feb 19, 2007 | 04:41 AM
  #151
1BADSS/SC's Avatar
this may be kind of a dumb question but, what is the point of the dual pass?? Does it work with the HE??
Old Feb 19, 2007 | 10:06 AM
  #152
gilbert's Avatar
it works even better with the he ur temps will drop faster ,more coolant and easy to bleed the system
Old Feb 19, 2007 | 10:08 AM
  #153
Admiral Jedi's Avatar
Also, it's much much more efficient. It's a pita, as I found out yesterday, but I think it's worth the few hours of misery.
Old Feb 19, 2007 | 01:08 PM
  #154
Blown 4-banger's Avatar
Dual Pass + Cobra HE + Ported Blower = A Wicked fast car with IAT2 that rarly gets higher than 150 degrees!
Old Feb 19, 2007 | 01:21 PM
  #155
srt-killer's Avatar
When are you going to help me with mine?lol
Old Feb 19, 2007 | 01:27 PM
  #156
You shouldn't need the dual pass, right now you have meth injection, and after that you'll have -300 degree nitrous sprayin so heat shouldn't be too much of an issue with you.
Old Feb 19, 2007 | 01:40 PM
  #157
1BADSS/SC's Avatar
I just ordered a HE. Can I just use the HE, or do I need this mod too? Money is kinda tight, I dont wanna break the bank...
Old Feb 19, 2007 | 01:49 PM
  #158
The dual pass is recomended but not required. I'd say its not as strongly needed for someone with a 2.9-2.8 as it is for someone with a 2.6-2.5.
Old Feb 19, 2007 | 02:46 PM
  #159
cobaltBlackss's Avatar
I still can't figure out the deal w/ the orifice
Old Feb 20, 2007 | 12:41 AM
  #160
Cobalt_Supercharged's Avatar
If it helps we never did it. It will just take you longer to bleed the system. I would highly recommend getting yourself access to a good vacuum pump like they use at dealerships to coolant flushes. That will really help prevent getting air in the system.
Old Feb 22, 2007 | 04:02 PM
  #161
MoparMan's Avatar
Sticking a vacuum hose on any orrifice weirds me out but I guess its a necessary evil
Old Feb 22, 2007 | 04:14 PM
  #162
BlackSS/SC's Avatar
All you do it break the end piece off the t-fitting that you can get at any autoparts store. Then you just shove it in the end of 1/4" hose, the end where it goes to the top of the heat exchanger. It's pretty damn easy.
Old Feb 22, 2007 | 06:19 PM
  #163
JESS!!! What up! I didn't know you were on this site!?!?
Ok back on topic
Old Feb 22, 2007 | 08:46 PM
  #164
BlilBT's Avatar
What it does is slow Down the amount of Fluid returning to the Reservoir!
Old Feb 23, 2007 | 12:27 AM
  #165
JapEatr's Avatar
South Central *********
i couldnt find a .040 oriface but i have a 1/8 in vacuum T and it looks just like the one in the instructions
think it is gonna be small enough ?
Old Feb 23, 2007 | 02:19 PM
  #166
blown06's Avatar
I am following everything just fine question is for those that have done this tank mod are any of you running a C/A front heat exchanger if so where did you run the orifice line if you removed the stock h/e? does the c/a h/e have a plug at top? Did you leave the stock h/e in with aftermarket or remove it? I ordered the C/A H/e and have not received it yet so thats why I ask.....
Old Feb 23, 2007 | 05:02 PM
  #167
BlilBT's Avatar
Local Auto stores Have them, It should work But try to find the 1s they say!
I'm Not running the C/A Heat exchanger , But I'm Running a Dual Pass & The stock 1! I Put the Line in the Bleeder Plug on the stock H/E
Old Feb 28, 2007 | 10:45 PM
  #168
I have the ca he that does no have anywhere for a bleeder line. Would it be a bad thing to run the stock and the ca he's?
Old Mar 1, 2007 | 01:04 AM
  #169
If you have enough room for both to fit you can bennefit from having 2 HE's instead of one. Just be sure to run the coolant through the stock HE first. Then route it directly from the stock HE to the CA HE. Your temps will stay lower longer and cool back down faster.
Old Mar 1, 2007 | 01:45 AM
  #170
X2!!!
Just got back from racin some SRTs, and at 160 mph my IAT2 was 178 degrees!
The second HE and the dual pass add insane endurance to your intercooler.
Old Mar 1, 2007 | 06:29 AM
  #171
blown06's Avatar
awesome thanks for the info i will get the stock with the second and do all the cooling mods cant wait friday=pay day= mod day lol
Old Mar 1, 2007 | 09:27 AM
  #172
BlilBT's Avatar
You will Love it, Just take your time & Reuse the Hose Guard's to help protect the Lines!
The dual Pass H/E I have with the stock 1 works awesome!
Old Mar 7, 2007 | 10:37 AM
  #173
A-Town's Avatar
Imgoing to try that!!!
Old Mar 7, 2007 | 10:57 AM
  #174
blown06's Avatar
sorry for the questions, one last one have all the mods in the garage i see the routing goes pump to manifold then to the heat exchangers back to pump. Would there be any benefit to run pump to stock exchange to C/A heatexchange then to manifold then to pump? I would assume there wouldnt be just a thought that popped into me head not sure what i was thinking lol
Old Mar 7, 2007 | 04:36 PM
  #175
BlilBT's Avatar
The Pump out port goes to stock H/E, Then to the 2nd H/E, Then into the Dual Pass Center Port thru the manifold, Then Back to the Pump in Port for the return trip! The last T before the Pump Ties in the Reservoir right before the Pump In Port!
