first htv 1320 received
Old Mar 19, 2008 | 07:47 PM
  #351
KillerBee's Avatar
Originally Posted by fast98
well this thing is crazy. it maxes out the maf sensor and the map sensor by 6200. so im gunna have to wait till next week to get the ls4 throttle body and 3 inch intake. my guess is this thing will push 26 psi. the top of second gear is useless. and the blower itself is way quieter then stock, no more of the marble noise. and the 60lb injectors are maxed out or its gunna need a fuel pump.
damn some serious power hey
Old Mar 19, 2008 | 07:58 PM
  #352
Josh@ottp's Avatar
the 2.75
Old Mar 19, 2008 | 08:03 PM
  #353
turboeco's Avatar
What about the 3.5"?
Makes the 60s usable and not max out the MAF.
Oh, and what did you have to dremel to get it to fit?
Old Mar 19, 2008 | 08:08 PM
  #354
Josh@ottp's Avatar
the map sensor right under the coolant hose has to be dremeled and turned so the blower will fit, the oil dipstick has to be bent some, and the two supercharger bolts on the passenger side of the car have to be ground flat on one side inorder for them to fit past the blower. i'll post pics shortly
Old Mar 19, 2008 | 08:12 PM
  #355
KillerBee's Avatar
now that is why we have test piolts so that they can fix these problems
Old Mar 19, 2008 | 08:13 PM
  #356
Witt's Avatar
I did the same minus the grinding of the two bolts. I also swapped the bypasses around as the TVS didn't have a provision for the boost control solenoid.
Old Mar 19, 2008 | 08:15 PM
  #357
Kibosh3's Avatar
soooo...wats the semi-verdict? you must be getiing some major airflow with that 2.75 if its maxing out the 60's...exciting
Old Mar 19, 2008 | 08:22 PM
  #358
Josh@ottp's Avatar
i couldnt get the two bolts to fit with out grinding and these are just some teaser pics
i also thought about changing the bypass but i figured i would save it for another day
Old Mar 19, 2008 | 08:24 PM
  #359
ralliartist's Avatar
looks awesome! It's how it should have came from the factory!
Old Mar 19, 2008 | 08:26 PM
  #360
Sunburst_SS's Avatar
man I can't wait to see mine tomorrow!!!! looks good
Old Mar 19, 2008 | 08:33 PM
  #361
Mnatvyc1223's Avatar
Originally Posted by Raven SS
i sold my first born...his name was michael
i'll smack you...
Old Mar 19, 2008 | 08:40 PM
  #362
mrphoto103's Avatar
From: Voted by the people, most likely to get pulled over by a cop
Good luck with it man! I'm heading out of town this weekend or id ask about coming over to see it...
Old Mar 19, 2008 | 08:41 PM
  #363
rallyracer's Avatar
OMG, fire that bitch up.
Old Mar 19, 2008 | 08:42 PM
  #364
can always come by when you get back....it'll still be on the car lol
Old Mar 19, 2008 | 09:11 PM
  #365
z24turbo93's Avatar
Is somebody going to run the 3.5" pulley with 60lbs injectors too see if it is doable or is everyone going to throw the 2.75" on?
I think lsjwannabe should put the 3.5" on and tune that too see if you can run 60lbs injectors and move down in pully size from there to give us an idea of what mods are need to run the smaller pulleys. Thats my opinion.
Old Mar 19, 2008 | 09:13 PM
  #366
I will be running the 3.5 at first
  #367
Josh@ottp's Avatar
sunburst has you covered
Old Mar 19, 2008 | 09:14 PM
  #368
yup, playing it safe before I throw the 2.9" on there haha
Old Mar 19, 2008 | 09:18 PM
  #369
z24turbo93's Avatar
Okay, cool.
Sunburst when you going to have yours up and running?
Old Mar 19, 2008 | 09:20 PM
  #370
blower should be here tomorrow.....so assuming all goes well I should have some time to get it on and tuned over the weekend.
Old Mar 19, 2008 | 09:21 PM
  #371
z24turbo93's Avatar
Awesome...will be glued to the computer for videos of this blower in action.
Old Mar 19, 2008 | 09:27 PM
  #372
Cobalt_Supercharged's Avatar
Sweetness. I can't wait to see the results.
Bumping the fuel pressure should resolve the fuel issues. Return fuel system with a 1:1 boost referenced regulator should keep enough fuel flowing for anything that TVS can throw at them.
Old Mar 19, 2008 | 09:34 PM
  #373
KillerBee's Avatar
i wanna see what the 3.5 does over a stock 205hp engine.
Old Mar 19, 2008 | 09:42 PM
  #374
quadracer0387's Avatar
im going to be doing the 3.5 first on stock internals with cooling mods, 3"tb and intake with full exhaust... dyno tuning set up for next friday!!!
the 3.5 with 60's and stock maf should be ok i presume
so the boost selinoid has to be switched?
Old Mar 19, 2008 | 09:45 PM
  #375
Josh@ottp's Avatar
if you want boost bypass for launching you should swap it
