Harrop HTV1320-LSJ using Eaton TVS technology
Old Feb 28, 2008 | 08:10 AM
  #1026
Omega_5's Avatar
Originally Posted by Rodimus_Prime
will a stock motor be even able to run this thing?
Yes... on a pizza sized pulley...
Old Feb 28, 2008 | 08:12 AM
  #1027
Pully Police's Avatar
I would say "yes" - but you would need a big pulley....and then you have to ask yourself "What the hell is the point, if i am not going to do all this other stuff anyways?" I am sure that it will be better than the M62 in terms of efficiency, so 260WHP with this blower could be done...but you would probably be operating the blower at the lower end of it's potential.
I am going to sit on the fence and see what happens before I jump on any bandwagons
Old Feb 28, 2008 | 08:15 AM
  #1028
Rodimus_Prime's Avatar
well stock internals should be good for well over 300whp, all thats needed is injectors
Old Feb 28, 2008 | 08:34 AM
  #1029
USMCFieldMP's Avatar
Rattlesnake Race Shop
Pistons are not rated for 300whp... they aren't even rated for 300 crank hp.
Old Feb 28, 2008 | 08:37 AM
  #1030
Omega_5's Avatar
Considering the efficiency of this new blower, if your lucky you might see slightly over 300WHP on a stock motor, depending on your tune.
With that said... you'd be pushing it to the edge of failure though.
Old Feb 28, 2008 | 09:05 AM
  #1031
Theres several guys running 400whp on turbos with completely stock motors when gm says the pistons are good until 300 its because they are assuming thats with the heaton still on, heat is what kills the pistons in this motor
Old Feb 28, 2008 | 09:18 AM
  #1032
While I somewhat believe that... I also know that GM says the Sleeves are only rated to 400hp as well... give them time... they aren't gonna break right away.
A stock DSM turbo isn't meant to push 25psi. But I've seen them do it... eventually they go to ****. I've seen them go to **** in as little as a month... and I've seen it take as long as 6 months.
Old Feb 28, 2008 | 09:25 AM
  #1033
djt81185's Avatar
TO make real power your gonna need pistons at some point...its only a matter of time. I was surprised at how brittle the stock ring lands are when we were disassembling my 1 motor. I was breaking them with my finger.
That said...I made over 300 whp on a mustang dyno on a stock bottom end and my stock pistons looked fine when we pulled em. I think proper tuning is what makes em last.
Old Feb 28, 2008 | 09:26 AM
  #1034
BRN169's Avatar
I would assume you could make more horse power with less of a chance of fragging the stock motor for the simple fact that this blower is simply more efficient, there is less energy siphoned off to make the same horse power when compared to the M62... That will result in more power to the wheels vs. to the blower. I would imagine it would also increase mpg in a daily driver...
Old Feb 28, 2008 | 11:30 AM
  #1035
Area47's Avatar
Rent me! per hour
lolfoonai
Old Feb 28, 2008 | 11:31 AM
  #1036
cobaltBlackss's Avatar
BRN169 I agree, I believe a significant increase will be made due to the decrease in parasitic drag compared to the stock blower.
Old Feb 28, 2008 | 11:32 AM
  #1037
lsjwannabe's Avatar
you do realize this is a bigger blower than our stock unit
Old Feb 28, 2008 | 11:33 AM
  #1038
redlineblueline's Avatar
Originally Posted by Area47
lolfoonai
roflecake
lolinthefamily
roflecopter
lolcano
  #1039
Raven SS's Avatar
and that it will take more to spin it
Old Feb 28, 2008 | 11:35 AM
  #1040
Area47's Avatar
Rent me! per hour
Originally Posted by redlineblueline
roflecake
lolinthefamily
roflecopter
lolcano
did you rofflecake in your pants?
Old Feb 28, 2008 | 11:40 AM
  #1041
i make roflecake in my pants from my lolcano
Old Feb 28, 2008 | 11:58 AM
  #1042
lawlarious
Old Feb 28, 2008 | 01:24 PM
  #1043
Well I renig then, but it is more efficient.
Old Feb 28, 2008 | 02:36 PM
  #1044
AlphaJaguar5's Avatar
OMG this couldn't be more wrong!!
hold on... yes it could be...
But only if he said the stock pistons were coated in peanut butter.
Old Feb 28, 2008 | 02:37 PM
  #1045
Omega_5's Avatar
Originally Posted by AlphaJaguar5
But on if he said the stock pistons were coated in peanut butter.
Old Feb 28, 2008 | 03:54 PM
  #1046
shabodah's Avatar
Originally Posted by Omega_5
Don't laugh. Mine are coated in peanut butter AND jelly.
Old Feb 28, 2008 | 03:56 PM
  #1047
Area47's Avatar
Rent me! per hour
thats not jelly....
Old Feb 28, 2008 | 03:57 PM
  #1048
shabodah's Avatar
thats not jelly....
Actually, it IS jelly. But it's NOT peanut butter....
Old Feb 28, 2008 | 03:59 PM
  #1049
Area47's Avatar
Rent me! per hour
wheeeeeeeeellllllllllllllllll
Old Feb 28, 2008 | 04:10 PM
  #1050
Raven SS's Avatar
Originally Posted by Harrop
- 1 - At least initially, we will honour the US$2,250 (+ shipping from Michigan). If the Australian currency continues to strengthen against the US$, we may need to increase the price to cover the exchange rate variation. When I did the business case for this project, A$0.79=US$1.00, it is now A$0.94=US$1.00
i was wondering if i was the only one that seen this...
now im not the smartest one in the world and please someone correct me if im wrong (us sailors **** exchange rates up all the time) but
if ur getting .79 for 1 of ours that means ur getting 1777.50 per HTV (.79 x 2250)
now if the exchange rate has increase to .94 for 1 of ours then that means ur getting 2115.00 per HTV (.94 x 2250) so why would u increase the price?
