HARROP TVS, What You Need To Know & FAQ
Old 04-11-2010, 08:41 PM
  #176
RooTBeeR's Avatar
is 350whp 300wtq possible with a stock pulied tvs and built engine(p&p head)? no meth or n2o
Old 04-12-2010, 09:21 AM
  #177
sput's Avatar
hmm.. no probably not. You need a smaller pulley and some higher octane than premium gas.
Old 04-12-2010, 10:34 AM
  #178
CobaltSSilver's Avatar
To quote the Golden Corral commercial....'the bird says no' (pirate voice)
Laughing at myself not your question....
Old 04-12-2010, 10:48 AM
  #179
Jrhdpaintball's Avatar
stock belt was slipping just a little bit for my tvs and 80mm pully. put on oversized tentioner, works great.
and napa had a belt listed part #D060702, looks identical to GM stock belt. cost 40$
Old 04-14-2010, 02:10 AM
  #180
RooTBeeR's Avatar
so what about a 70mm + meth + p&p head?
Old 04-14-2010, 12:23 PM
  #181
sput's Avatar
Maybe this will help you: https://www.cobaltss.net/forums/dyno-results-170/official-dyno-thread-194257/
Old 04-20-2010, 08:14 AM
  #182
jrzdude's Avatar
I heard someone say that the Stage 3 tune is no good? Are they speaking of the one from O t tp?
Old 04-20-2010, 11:28 AM
  #183
Could I use a GMS3 PCM and trifecta on top of that for this S/C upgrade?
Old 05-25-2010, 06:02 PM
  #184
impalaboy327's Avatar
I have a question for you TVS guys. How hard is it to get the oil filter out with that bigger supercharger? Its all ready a slight pain in the butt
Old 05-25-2010, 06:07 PM
  #185
Rent me! per hour
Area47's Avatar
it still sucks.
Old 05-25-2010, 07:36 PM
  #186
Sizzle06's Avatar
Originally Posted by Area47
it still sucks.
x2...
Old 05-25-2010, 09:28 PM
  #187
freakta's Avatar
i dont think its any worse but its not any better
Old 05-25-2010, 10:38 PM
  #188
Sizzle06's Avatar
It sucks when you have big hands
Old 05-25-2010, 10:43 PM
  #189
Pyros777's Avatar
You could use the GMS3 base and any custom tune, whether it be trifecta or HPT. I did 278whp/255lb-ft on the stock TVS pulley on 93 octane with a trifecta tune. Have yet to dyno my HPT tune. (no meth)
Yeah its not pretty, but you can still get the job done.
Old 05-25-2010, 11:45 PM
  #190
Billig ss/sc's Avatar
Just did it today haha. It seems like it'd be easier with the TVS at first, but then you have to pull the filter up and you're fucked I just finagle it out under the blower and up towards the front of the car.
Old 05-26-2010, 11:52 AM
  #191
RooTBeeR's Avatar
yeah exactly, with the m62 i could get my hand down from the top and get it out, now i gotta do it all from under the tvs to the front of the car
Old 05-26-2010, 11:56 AM
  #192
csementuh's Avatar
Reallllllllly debating a TVS. Anyone have experience with a 2.6" setup going to a TVS? If so, is the increased in power and pull a good noticable increase? I'd likely stick with the stock pulley and 60#'s for awhile. Worth it..?
Old 05-26-2010, 12:04 PM
  #193
RooTBeeR's Avatar
area's the only one thats gone that small as far as i know
Old 05-26-2010, 12:21 PM
  #194
csementuh's Avatar
I mean a 2.6" setup on the M62 to a stock pulley on the TVS...
Old 05-26-2010, 12:27 PM
  #195
RooTBeeR's Avatar
haha, oh my bad
Old 05-27-2010, 02:49 PM
  #196
csementuh's Avatar
So I finally decided to buy a TVS. Should have it next week!
I'm going to run on my 60#'s for awhile with the stock pulley and see how that goes.
Do I need one of those fuel pump rewire kits?
Also, is there any TVS specific things that need tuned for? I'm assuming I can adjust the MAF scaling and timing a bit with my existing M62 2.6" tune and the car should run pretty good. Anything else I'm missing?
Old 05-27-2010, 03:06 PM
  #197
InfraRedline's Avatar
You shouldnt need the rewire for the stock pulley. Congrats on the purchase!
Old 05-27-2010, 03:16 PM
  #198
South Central *********
JapEatr's Avatar
finally got it huh?
Old 05-27-2010, 03:31 PM
  #199
csementuh's Avatar
Yes, sir
Thanks! If I get 80#'s and drop to a smaller pulley at which point would I need a rewire or other mods?
I'm trying to get away with reasonably safely running a TVS as much as possible with a conservative tune. I want to stay away from meth and a return style fuel system for now. How small of a pulley can I run on 60#'s and what about 80#'s?
Old 05-27-2010, 06:05 PM
  #200
Let me know how that works out for you. I have a 2.8 sitting here, I planned on getting a set of 60lbs injectors but if I can get away with going to 80's and putting in a TVS with some major power I'll stick with my 2.9 and GM s2 tune till I get the dosh then go all out. I too want to run the TVS but don't want to mess with huge upgrades on the fuel system, and I too do not want to run methanol injection E85 ect... Just want to use pump gas and hope the block holds up stock...if not then I will put i the rings pistons and head bolts. Beyond that just too much dough and risk on a DD car. i would need to snag another DD and then push this one as a drag/track only car that I play with on weekends.
Quick Reply: HARROP TVS, What You Need To Know & FAQ
