HELP ME OUT! Cobalt ss/sc build !
Okay maybe you guys can help me out this is my set up waiting to be put on in the spring.
Cobalt addiction stage 6
ZZp downpipe header combo
Meghan Catback Exhuast
engine and tranny mounts
injen CAI
Slotted rotors and hawkeye brake pads
BM short shifter
Ingalls TD
Sportlines
CF Hood and trunk( pending group buy which is up )
Now my question is ....Now im about to buy
1 x Cobalt SS/SC Adjustable Rear Strut Bar
1 x Cobalt SS/SC Front Sway bar links
1 x Cobalt SS/SC Traction Bars
from http://bwoodyperformance.com/
is this 3 all the same and im pretty much wasting money or are these 3 parts going to benfit me in some way keep in mind the stage 6 alone is est. 100 hp and trq increase i believe...My baseline when i dynoed was 226. Now im still stock jsut waiting for thins to warm up and yes i know i have to get a clutch but mine is stil fresh when i see it goign figure then ill invest.
injen CAI
BM short shifter
Ingalls TD
Sportlines
dude you're going to need some cooling mods, hardcore, and a GOOD tune. Otherwise things are going to explode and your engine will be angry with you.
You're going to need those traction bars yes, and if you wanna turn the other two will be good. But yeah man, instead of the cf hood and trunk, get some cooling mods, you're gunna need them.
+1 to scythe but another thing.. don't expect 100 hp and trq... your going to need a retune... get some meth or water injection something or you'll go boom..
did you already buy the CA stg 6? if not then just get a 2.7 pulley 42lb or 60 lb injectors and a good tune there are some really good tuners in you/ our area so that will help
Original Hayden Fanatic
Stage #6: 2.5 ZZP Interchangeable Pulley system , 2 step colder ngk IRIDIUM spark plugs , GM shortened belt , ZZP Adjustable Tensioner , 60# Siemens Injectors , Injector Wiring Harness, CA Methenol Kit , CA Heat Exchanger Kit, CA Dual Pass Intercooler Plate, CA nitrous controller , Stage #6 Retune ...
Yes the kit come with the heat exchnager and dual pass and the meth kit.. This and the the bwoody equipment is the any part i didnt get yet...cause im waiting on a response from ken on pricing with the ca kit since ill be getting appearance mods from them also figure mayb hell help me out a bit and bwoody parts i just ordered : )..... but yea man im just tryin to pull as much out of this car as possible not sure if im gonna upgrade to the tvs later on or not...
And yea i getting it all done at tune time performance plan giving them a call to see if they will install dyno and tune..
What gains do you think i should expect? im hoping to be putting out more than 300 hp ( a man can Dream!)
WhineSSbaby
Sep 1, 2020 12:39 PM
satisfied
Oct 19, 2015 12:35 AM
