Installing Pistons
Old Aug 12, 2009 | 06:57 PM
harryresh's Avatar
Installing Pistons
Is it possible to install new pistons without removing the engine from the car. I was wondering if I could just remove the head and drop the oil pan. Disconnect the pistons from the crank and push them up through the head.
Old Aug 12, 2009 | 07:06 PM
HunterKiller89's Avatar
yea, several members have done it this way
Old Aug 12, 2009 | 07:08 PM
ebristol's Avatar
Does anyone know about the GM Stage 2 kit? Is it reliable?
Old Aug 12, 2009 | 07:10 PM
sport08's Avatar
Originally Posted by ebristol
does anyone know about the gm stage 2 kit? Is it reliable?
lawlz!!
Old Aug 12, 2009 | 07:17 PM
bwalker0510's Avatar
its very simple. just look up the gm build book on google if you get confused. it took me about 7 hours to get the motor apart and back together taking my time and inspection everything. never took the block out. check out this guys thread i found it very helpful.
https://www.cobaltss.net/forums/show...iamond+pistons
Old Aug 12, 2009 | 07:20 PM
harryresh's Avatar
hey ebristol, get the **** out of my thread!
Old Aug 12, 2009 | 07:25 PM
mrsilent13's Avatar
yea man...thats how i changed my pistons out....put it on jacks and took off the head and the oil pan...and then removed the rods from the crank and pushed up on them...they pop right out...and installation is backwards..you might want to get a ball hone in there to make sure the new rings sit in right...and then re install everything..its time consuming but very do able...
Old Aug 12, 2009 | 07:37 PM
harryresh's Avatar
what about the crank and cam sensor? did you have to do a relearn?
Old Aug 12, 2009 | 07:40 PM
lsjwannabe's Avatar
If you time the car correctly you are fine.
Old Aug 18, 2009 | 11:33 PM
damien's Avatar
Timing is a bit tricky. Just take your time and research before you do it and you'll be fine.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
