Intake manifold questions
Old Jan 2, 2011 | 03:35 PM
SSteveSC's Avatar
Hey guys, i'm doing a custom turbo swap and I've came across something that im a bit baffled on..
In the picture above it looks like theres a rad fluid port that goes into the intake manifold somewhere, where does it go? And where do I route it to after the turbo intake manifold is installed. Guys with the rd fabs intake or hahn intake should be able to answer this one.
Old Jan 2, 2011 | 03:36 PM
05Slowline's Avatar
pvc port prob. i have a block off plate welded on mine
Old Jan 2, 2011 | 03:37 PM
05Slowline's Avatar
only tubing you need is one for vacuum to t to bov and wastegate and brake booster hose
Old Jan 2, 2011 | 03:39 PM
mexi_loco's Avatar
it is a pcv port. I'm curious myself however, especially since I'll be running a catch can.
Old Jan 2, 2011 | 03:46 PM
SSteveSC's Avatar
Will I need this for emissions though? I notice a lot of people with the Hahn racecraft sheetmetal intake have a rubber hose going somewhere from this port.
Old Jan 2, 2011 | 03:57 PM
05Slowline's Avatar
don't need it
Old Jan 2, 2011 | 04:01 PM
TurboTechRacing's Avatar
Block it off, the intake manifold flange can do this, on the new intake manifold. It is not needed.
Old Jan 8, 2011 | 02:36 PM
bolus's Avatar
If you block that off you are going to need another way to vent crankcase pressure. The tiny vent on the valve cover isnt enough if you are going to be running any higher levels of boost
Old Jan 8, 2011 | 04:43 PM
SSteveSC's Avatar
what if I get the oil cap vent? will I be ok then?
Old Jan 8, 2011 | 04:55 PM
whyyoumadson?'s Avatar
we block the one off in my car burned oil like a ****. made a revision and welded a channel into my manifold so that it was there again...no more smoke. then again im an lnf
Old Jan 8, 2011 | 05:01 PM
05Slowline's Avatar
that's what i'm going to do, 15psi-20psi prob. if it's a problem then i'll just get a bigger bung welded on the back of the valve cover and do a catch can deal.
Old Jan 9, 2011 | 11:43 PM
bolus's Avatar
There are oil filler cap replacements. Im using this -10 Adapter to an electric vacuum pump
Valve Cover Adapter, AN Valve Cover Adapters: Metco Motorsports
Old Jan 10, 2011 | 11:27 AM
Red05SS/SC's Avatar
I tapped the port on the head and installed a barb fitting and ran the hose to a catch can that I have mounted underneath the intake manifold.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
