Intercooler problems
Old Sep 9, 2009 | 09:24 AM
harryresh's Avatar
I installed the Max Redline FMI. I have coolant comnig out of the cap which is rated for 15psi i think. i dont understand where i could have pressure building up b/c i have the dual pass which should make it fow easier. i also have the "stu" mod, so maybe the extra coolant? i dunno if it leaks while im driving but it def leaks when its parked for a little bit after im driving. any ideas?
Old Sep 9, 2009 | 09:26 AM
rnjmur's Avatar
Only thing that should cause pressure in the system is a kinked or blocked hose.
Old Sep 9, 2009 | 09:32 AM
jimbos'ss's Avatar
did you flip the cores when you did the dual pass install?
Old Sep 9, 2009 | 11:44 AM
harryresh's Avatar
yess
Old Sep 10, 2009 | 08:14 PM
Jared B's Avatar
I Have the same problem i cant figure it out
Old Sep 10, 2009 | 11:11 PM
harryresh's Avatar
its an open vent system?! i was thinkin it might be the weight of the extra coolant but i didnt have this problem until a couple of months afterwards. it drips enough to make 5" diameter puddle after i stopped running the car! ill check my hoses when i do my build this winter. since it seeps out slowly, i might just put a higher psi limiting cap on it.
Old Sep 10, 2009 | 11:21 PM
Hockeyman's Avatar
with my CXR fmhe, the cap is rated at 5psi, and i've never had a problem with it leaking.
Old Sep 11, 2009 | 07:11 AM
harryresh's Avatar
do you have the "stu" mod?
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
