Updates?
5 Attachment(s)
ok, we're back on the project :)
sorry, I had to prioritize my finances for the past year. Having a baby girl makes a huge difference........and car hobby becomes the last of my priorities. Anyways, when BTF was test driving the car on the street last year, the timing chain skipped a tooth or two. So that was a major blow. We talked about getting a smaller turbo so we can spool faster. Basically replacing my small turbo (gt2871r) with a gt2860r. And we have to pull out the motor so he can inspect the internals if there were any damages due to the timing chain skipping. While the motor was out, he also replaced the k1 rods with Carillo H-beam rods. We dodged a bullet, and luckily no internal damage found! Just found out today that My plan of replacing my small turbo (gt2871r) with a smaller turbo (gt2860r) to get a faster spool ....won't work after all. I thought these gt28 based Garrett turbos share the same size turbine housing, but I guess not . The gt2860r that I bought won't fit the Tial turbine housing used for my gt2871r. We'll just stick with my original turbo then. Attachment 13557 Motor is all back up. I'm glad nothing was destroyed. BTF gasket matched the head with the Werks phenolic spacers Attachment 13558 Stock Intake is being prepped to be matched as well Attachment 13559 Stock intake manifold was gasket matched and ported clean Attachment 13560 Secondary injectors already plugged in! Attachment 13561 |
Originally Posted by KonnerTomlinson
(Post 7447414)
Can't believe I missed this thread being here . Definitely a cool setup for the secondary fuel system from what I've seen. So you ditched the Nx kit for a custom fuel cell ?
yes! |
Looks awesome
Originally Posted by SKY888
(Post 7570101)
I thought these gt28 based Garrett turbos share the same size turbine housing, but I guess not . The gt2860r that I bought won't fit the Tial turbine housing used for my gt2871r. We'll just stick with my original turbo then. Exciting build! Daniel |
Originally Posted by TurboWood
(Post 7570217)
This is very strange. Can you clarify what turbo p/n's you have and what doesn't fit? I was planning on this combination (Tial + GTX2860R) so I would like to understand if I'll have issues.
Exciting build! Daniel I believe I bought the units from the skyline motors also called the ultra compact t28 |
Why did you go back to the stock manifold instead of werks?
Originally Posted by taintedred07
(Post 7570272)
We suspect that it caused rough power up top...and also caused slower spool. Now that the engine is already out, might as well put the stock manifold back |
1 Attachment(s)
1 Attachment(s)
2 Attachment(s)
Caswell Ultra Wet Black Powdercoat
Attachment 13524 Big thanks to Turbowerx for sending me the Exa-pump (ultra high performance electric scavenging pump for my turbo) This is the only available spot inside the engine bay Attachment 13525 |
2 Attachment(s)
stock intake manifold w/ port injectors have been powdercoated and ready to be installed.
LE5 bigger throttle body was also fitted in this manifold. Attachment 13521 manifold installed, but a longer charge pipe needs to be re-frabicated Attachment 13522 |
I love this car. Can't wait to see more of it when completed!
Originally Posted by 574
(Post 7571041)
1 Attachment(s)
Fabrication of New cold side pipe that fits with stock intake manifold was finished & installed today.
Big thanks to Hurst-shifters for sending me Line-lock kit! Also installed today Attachment 13499 |
woot!
In.
2 Attachment(s)
No engine leaks so far!!! :)
Attachment 13418 Attachment 13419 Update: We decided to not use E85 for the secondary fuel system. We will be using VP M1 pure methanol instead. . |
What are you using for the primary fuel e47?
Originally Posted by KMO43
(Post 7572243)
PI = M1 |
On setting B it hits 40psi in about the same time. We just wanna get clean combustion up to 7500 with 40psi. That is the goal, and no small feat here with 2 fuel systems( direct injection and port fuel M1),2 boost control regimes in 2 different controllers.
You can feel with no uncertainty when the large gate opens fully (after LP turbo is lit a little). The increase in Mass flow to the secondary turbine is substantial and the LP pretty much walks around the HP turbo, leaving it at a PR of like 1.2-1.4 pending on RPM. This was what we were hoping for as data shows 8-12 psi positive delta across the engine in some spots. The only real concern at this point is T2 compressor. At a PR of 3.2 ish discharge temps are in the oven at high rpm since the GT42 is doing the heavy lifting by that point. The timing paint on the compressor of the GT28 is cooked to a different color. Its obviously experiencing significant thermal loads in addition to the mechanical forces acting on it as it approaches max shaft speed below 4krpm.(inferred from MAP,MAF and compressor map) . Perhaps interstage intercooling would reduce the stress on the HP compressor. I have a leftover AEM meth kit that be could plumb into the LP compressor and tie it to LP pressure. SInce that is pre BOV it will have to be less then 20% alcohol or pure water. First rip on the street, about 20psi at 3900 and 30psi at 4900. Way better spool response using the stock manifold :) I am having a hard time posting videos of the engine start up.....as well as the first run on the steet! If you want to check them out, pls go to my facebook page! |
1 Attachment(s)
AEM water methanol was re-installed so we can add inter-stage cooling.
the small turbo is currently being cooked as what I stated on the previous post. We will be using pure water to cool off the small turbo with this AEM w/m kit during HIGH BOOST (probably from 25-50psi) Attachment 13305 |
so it runs?!?!
(Post 7573730)
so it runs?!?!
if you were asking if it already runs.........yes. A couple of days ago. i can't post the videos here...but you can see them on my FB account. thanks. |
2 Attachment(s)
water/meth spray installed for inter-stage intercooling......which should help engine delta
Attachment 13294 all my controllers are nicely tucked in a safe environment: Attachment 13295 |
