1 Attachment(s)
Disco Potato turbo definitely made the the system way snappier and wakes the Gt4294r up alot faster
At 6200rpm - 52lbs ve flow (40psi) Too bad at 3800 (35psi), the vibrant vanjen clamp broke today! :( I believe time to upgrade to Wiggins Clamp! Attachment 12160 |
Glad to see this build progressing! Definitely a mean sky
That's a crazy build, I can't wait to see more of it
4 Attachment(s)
after more than 5 years of waiting.....LIPSTICK is back!!! :)
Attachment 11324 Attachment 11325 Attachment 11326 Attachment 11327 |
Videos on private
Car looks sweet. How about unlocking the video so we can see it?
sorry!!!
click on this guys.....see if it works. I'm not good with this kind of stuff :) |
5 Attachment(s)
Today, I professionally detailed Lipstick inside and out! :)
Attachment 11315 Attachment 11316 Attachment 11317 Attachment 11318 Well this morning was my first time to drive her around the city and highway to get used to with the new power. I'm sory no videos since I don't have a gopro. I wana do it with my phone but it will not be safe. All I can say is, even with the low boost setting (37psi), it as so worth the wait! Instant spool by 2800 rpm and full boost by 4500rpm! The sound of the engine and the look of the car are such an attention whore! I can't wait to ty the high boost setting (45psi) Attachment 11319 |
love the hood
So much win on that car!
Great to see an update on this!
Did you get her on the dyno yet? |
1 Attachment(s)
thanks guys.
last year, before my bates block died, with s1 cams, and stock head.....it only made less than 500whp at 35psi on the mustang dyno. The head was lifting and giving us all sorts of trouble so we stopped dyno This year, we upgraded to a zzp girdled block, s2 cams, and some headworks, and started boosting above 37psi. I currently have a low boost (37psi) and high boost settings (45psi). But didnt get the chance to go on the dyno. We are assuming the low boost setting is at least 530whp on mustang dyno here's the road tuning that BTF made for me. As you can see the boost is high, BUT the timing is only 7 degrees, AND no signs of any knock whatsover. It can easily gets way more whp/tq if we bump that timing to 15-20 degrees. We can do that later on, since the power is way more than I can enjoy especially on the streets. Just want to get comfortable with the power first....then later upgrade for more power. Safety first :) Attachment 11314 |
Why wouldn't you run more timing at less boost? I made 511 @ 27.3psi
Badass build, makes me want a sky
be careful with the timing that low, itll drive the egt through the roof
Originally Posted by KMO43
(Post 7622897)
but remember that with compounds, it loves high boost. having two turbos, we have to make each of them happy with their respective PRs. The interactions between the two turbos is the key, or it will run like crap We played with different PRs of both turbos, and with my current set-up, and this is where both of them are happy. Trust me it was a very frustrating tuning experience since the set-up is very complicated. That's why we focused on finding the right PRs first. Then we can just add more aggressive timing later. car runs perfectly right now, without any hiccups. The transition between the small and big turbo has no hiccup, which is awesome. Even the injection of methanol by the port injectors is very smooth. These are the key at the moment, and I love the way she drives and plenty of power in the streets. We'll add more aggressive tuning later. |
Originally Posted by Sharkey
(Post 7622911)
thank you! Yes, they're under control at the moment! :) |
the big issue with my current set-up is my oil catch can.
It's collecting some oil during very high boost. Afraid that the turbos will be sucking oil. What have you guys done with your OCC set-up? |
Powell PCV system v3.
You'll have to talk to John since I imagine there will be a few extra lines with compound turbos. https://cimg0.ibsrv.net/gimg/www.cob...86f49d0191.jpg |
sweet, thanks colodude
BTF is more than qualified to be handling tuning on this car. I can't wait to see her turned up!
What fuel are you running? Full methanol on the port side? What in the DI side? How are you controlling boost MBCs?
(Post 7623348)
VP m5 (PI) Small turbo - HPtuner Big turbo - electronic boost controller (turbosmart eboost 2) |
I'd run the DI on E47 can turn up the spool
1 Attachment(s)
