1 Attachment(s)
today, started using the secondary injectors spraying VP M1 methanol
M1 methanol + water + careful programming of transition = DELTA P! GT42 is the light blue line/green for turbine. Red is intake manifold pressure, yellow is turbine pressure 1 Note the green line in the top graph, that is MAF lbs/min. It has been flattened in the CAL to reflect the M1 systems addition to the total fuel load. The white line at the bottom Graph however is raw MAF frequency and truly should reflect mass flow changes... Although it slowly increases with RPM it seems to plateau more or less once 32 psi is achieved and the transition occurs of turbos. If you run it setup for absolute mode on the primary gate (PR High in green graph #4) and keep that a steady 2-1 PR, system response is faster, but Delta P overall is negative by a half Bar or so. The twist comes with the MAF freq more or less is the same in either mode, having a positive delta or negative at the cyl head. Attachment 13291 |
For the ones who don't have facebook do you mind posting up one video :) lol could be just a teaser lol anything.
Crazy build man, Keep it up |
What size gate and spring do you have on the small turbo
1 Attachment(s)
Initial dyno run at mustang dyno
440whp at 33psi It is as far as it can go today without changing the LP turbo gate spring. Attachment 13260 |
(Post 7574281)
1 Attachment(s)
baby steps........since a lot of stuff going on with the interactions of the two turbos.
Need to be careful at 35ish psi Attachment 13244 still has a lot of bugs to fix............and will at least boost 40-45psi . |
1 Attachment(s)
Of course, another speed bump on this build :(
Engine started over heating, and BTF saw that on my killer glass radiator tube (transparent glass), coolant wasn't flowing. He suspects that water pump died :( Attachment 13243 |
Originally Posted by SKY888
(Post 7574380)
20psi
45psi =~4.1pr. If you can get each snail to run at a 2.0pr (~14.5psi) your overal system efficiency will increase. Even bossing towards the lp snail a little beyond equal may be ideal, since it will be more efficient at higher airflow than the hp. Would have to study maps based on pr though.
Just offering input. I've done something similar. Letting the big guy do the big work was the key. |
3 Attachment(s)
Well for the past few days, while the head was out, Rick Gifford aka BTF found out a lot of issues and probably caused coolant flow stoppage, as well as limited the whp on dyno:
1.) #SMGmotoring #fredsimmonsjr is a CROOK!!! Save your money, and go somewhere else! He supposed to install aftermarket valves that I supplied him, and do valve job/headwork but he ripped me off! He never did any headwork! Plus on top of that, he plugged old stock valves on my head! He even used different kinds of valves! #SMGmotoring #fredsimmonsjr is a POS scumbag! I paid him full price and referred customers to his shop, in return he stole my aftermarket valves, and didn't do his job! Even my good friend Joshua Guzzetti with his solstice "project scarab", this SMG shop installed used cam followers which caused the catastrophic engine damage on his build :( 2.) head started lifting after 35psi and regular arp studs need to be upgraded. We recently got ARP L19 set which should be able to handle 45-50psi. During high boost, coolant was being pushed out. Hopefully, after all these issues have been fixed, we can achieve the whp goal! Attachment 13172 Attachment 13173 Attachment 13174 |
L19'S Suck if you don't want to have to keep changing them (corrosive)
swap to the arp 625+ ones. much better |
Originally Posted by 06blackg85ss
(Post 7576582)
swap to the arp 625+ ones. much better Not worth it |
um, nope like 450. pm advise he has the part number for the ones that work in the ecotecs.
we run em in our builds. no problems |
(Post 7576711)
we run em in our builds. no problems Oh well. |
what wheels are those?
(Post 7576814)
That thing looks mean as hell...
2 Attachment(s)
Well, for the past three weeks lots of parts were upgraded to these:
- ZZP gen 3 LDK girdled block (BTF will o-ring) - ZZP stage 2 cams - brand new LNF head, valves, crank. - ARP L19 head studs Will continue to use Carrillo H-beam rods, Wiseco Pistons, and Supertech valve springs Attachment 13027 Attachment 13028 |
You're starting over again?
Originally Posted by KMO43
(Post 7579480)
All those issues need to be addressed so my motor can run properly. So to answer your question, yes. If we didn't pull out the engine, we won't discover all underlying issues. We'll be re-using the Carillo h-beam rods, wiseco Pistons, and supertech valve springs. With the fresh & upgraded parts, I'm hoping the motor will finally work to its max potential |
(Post 7579530)
(Post 7579577)
That's what I'm curious about cause on stock engine e25 and meth with 7163 I made 481. So I'm hoping for some big LNF numbers from your setup!
Thanks! |
Good luck with the new parts. Looking forward to see the results when it's all together!
(Post 7579645)
Now that there are no more undelying issues that we didn't know about......with a fresh start of good solid parts, I'm hoping that there will be no more road blocks *crossing fingers* |
1 Attachment(s)
New upgraded parts installed:
- zzp Girdled LDK block - zzp stage 2 cams - BTF LNF head (full port match & bowl blend) - gt2860rs turbo - ARP L19 head studs Installed and will re-use: - gt4294r turbo - Carrillo pro H beam rods - Wiseco pistons - Supertech valve springs - Opel DI injectors Attachment 12161 |
