LIPSTICK's 800hp first LNF compound turbo/engine build!
#126
I'm hoping that the 60mm tial wastegate will be enough.
other people also use a pair of 44mm wastegate (instead of 1 big wg) to make sure that there will be no issues....
#130
Tuning is the key and involves lots of it, so the bigger turbo will do what it supposed to do
#131
since I'll be hoping to get some serious torque/whp, I am upgrading my OZ wheels with nitto nto5s...............to wider wheels and tires!
I would like to give thanks to TOYO TIRES for sponsoring me a set of PROXES R888! 295/30/18 on all corners Home | Toyo Tires
and definitely thank you to FORGESTAR WHEELS for sponsoring me a set of customized F14 wheels! These wheels are FLOW-FORMED, technology used on Formula 1 and Indy cars! They are very light and strong! Forgestar Wheels | The Worlds 1st 1 piece lightweight flow formed wheel lineup
18" x 10" (matte black) on all corners
weighs less than 20 lbs!
I can't wait to receive these bad boys!
Now, the kappa owners have more/better choices for wheel selection!!!
#133
I believe with correct offset, I will have no rubbing issues.
I just need to roll-out the rear fenders if needed. The KW v3 coil-overs, I might raise them if needed as well.
A couple of sky/solstice actually have 11" wheels on all corners. The one guy, only added an 1" spacer at the rear. He doesnt have any rubbing issues inside. I'm assuming that, I only have 10" wheel, so I shouldnt have any rubbing issues. If I get some, I'll probably add 3/16" spacer or so....but I doubt it.
#134
When cryo treating your parts, what kind of changes do you see in the dimensions? I am thinking about getting some rods and other parts treated, but i was worried about the dimensional stability. I wouldnt want to have to machine the parts back into tolerance if the shrink during the process.
#135
dimensions will not change bro. Probably in their very microscopic level, some changes will occur.
even before, all of my friends have shot peened their rods. Now you can do a combo of shot peening and cryo-treatment as well...
#136
#137
I was just curious. But thats a good explanation. I wasnt sure if the molecular structure was pulling together shrinking the part. Im a plastic injection molder my world revolves around shrink rates and part shrinkage. I over thought it basically.
#138
No, you didn't really over think it, you thought it over very well. That DOES happen, but not to the degree it would in a plastic piece. The more dense a material is, the less expansion and contraction there will be due to temperature and other factors.
#139
ok your right. in my industry im dealing with parts that can change .050 in a few seconds based on melt, pressure,time,cooling, viscosity shift up to 30% so on and so forth. metals being much denser material are less prone to huge swings in dimensions. I understand what you are saying. I was on the right path at least.
#140
Thanks NITROFREEZE for the first batch of stuff that were cryo-treated (BATES shafts/chain tensioner spring/oil pump gears/rocker arms/head studs and SUPERTECH 78 lb springs/valve seats/titanium retainers and GMPP driveshaft! This will make sure that they are 30-50% more durable!
I was lucky enough that one forum member sold me a pair of LNF axles and driveshaft that were only used for 500 miles for only $200. So I had them cryo-treated, and I'll have my current axles and driveshaft as a back-up
Next batch going for cryo-treatment will be SPEC clutch and flywheel, hubs/sliders, and more drivetrain parts.
and last batch will be the two turbos, manifold, and pipings....
#143
i understand why u want to cryo some parts but wont it make it make other more prone to snapping like tungsten? valve springs as an example. i am not bashing just trying to understand.
#145
I found some info that explains it better for me. Maybe it will help here.
http://www.nitrofreeze.com/RETP3034Cryo.pdf
#146
thank you!
#147
yes, I understand, you are not bashing bro. Thank you.
I am no expert in regards to cryo-treatment, that's why I always do research on my own, as well as asking experts such as Ray bates, Martin of supertech, and Ryan of nitrofreeze. They know their products inside and out.
Cryo-treatment will improve strength, ductility, and toughness of the metal products that I had treated, especially the valve springs. Valve springs will benefit, and will not snap since the ductility and longevity will be improved.
In regards to the valves, I am planning to send only the black nitrided valves (intake valves made out of stainless). But not the Inconel Exhaust valves. According to Ryan of Nitrofreeze, "The black nitrided ones will benefit far more than the inconel. The reason being that the black nitride are made of stainless steel. The hardness of the valves will not change or go up. Cryogenics toughens up the molecular structure but not the actual hardness of the part.
HTH.
#148
Or you could wait for borg warners new turbo coming out... Next to no turbo lag at all. Spool time of our KD04 and power output of a S256, dual wastegates, electronically controlled, pure genious. lol!
