LNF ZZP ported head and cams
Old May 10, 2013 | 06:41 AM
Black_Mamba_09's Avatar
Hey guys, I am interested to see who is running ZZPs ported head with cams on an LNF.
Old May 10, 2013 | 09:37 PM
rking7's Avatar
I am. Love it.
Old May 11, 2013 | 01:25 AM
Whats your set up? Is the car built?
Old May 12, 2013 | 01:30 AM
cmiller8006's Avatar
I will be once I put it back together.
Old May 14, 2013 | 05:34 AM
I figured you already had that set up cmiller. I building the my motor when I get back from Afghanistan. I am still unsure on what turbo I want. I know we talked about turbos already.
Old May 14, 2013 | 07:05 PM
Nope was on stock head, had cams tho.
Old May 14, 2013 | 11:43 PM
taintedred07's Avatar
I'm already on e85, bolt ons, stock turbo. Thinking in the long run of things, I think I'm going to swap to their ported head with cams and everything so I can already have that taking care of for a future build.
Old May 24, 2013 | 11:46 AM
rking7's Avatar
Not built yet. Fully bolted, stock turbo. The motor has 99,300 miles, and is loving the new top end. I have the rotated front and rear trans mounts running continental dws extremes, and hooking up, nor wheel hop are an issue. I can highly recommend this mod. The only parts on my car the aren't zzp are the Hahn intake, and Hahn cat back exhaust. I threw one code while driving pretty hard for an extended period. It was P2096, and it cleared itself. So, no big deal. Hope this is what you were looking for.
Old Apr 1, 2014 | 08:37 AM
crashher0's Avatar
When is a ported head suggested? From what I have read on the LNF engines its not a huge performance gain. Basically none on the stock turbo but when does it start benefitting on a big turbo set up like a zfr or S25x snail? Im in the process of debating a ported head with cams or just cams for an S256et build.
Old Apr 1, 2014 | 02:54 PM
Just cams
Old Apr 2, 2014 | 09:46 AM
crashher0's Avatar
So if I were shooting for 450-500hp just cams will do fine? When does the head porting really show numbers are we talking 500hp+ beasts?
Old Apr 2, 2014 | 01:43 PM
I'm going to be well over 500+whp and I didn't touch my head
Old Apr 2, 2014 | 05:35 PM
crashher0's Avatar
Awesome great to know!
Old Apr 2, 2014 | 06:33 PM
Hopefully you will get to well over 500 with no head work.
Old Apr 4, 2017 | 07:39 PM
theamericono's Avatar
I am looking for 500 hp in the long rune off my 08 ss
looking to upgrade the head to zzp ported,cammed and tune
i need to go into the motor anyways to replace the water pump,timing chain and headgasket.
would this be the best way to go? I am hoping to upgrade to a bigger turbo soonish. The car was running hot @245 and worried if the head comes off for the headgasket it will need replacement anyways.
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
