lsj air to air problem
Old Jun 7, 2009 | 11:04 AM
freakta's Avatar
lsj tvs air to air front mount.
the car is sucking really hard on the piping and couplers of the front mount setup we made.
vacuum reads 20 on stock boost gauge.
any ideas or suggestions please help. need car driving tonight.
if you can call me. 978 833 7433
Old Jun 7, 2009 | 11:52 AM
2K5SS/SC?'s Avatar
WTF? Pics of said setup?
Old Jun 7, 2009 | 11:56 AM
Dayta's Avatar
pics of this,
id like to see how this it set up
Old Jun 7, 2009 | 12:07 PM
freakta's Avatar
thanks guys for being so helpful. no its not a ricer thing. picture any air to air setup and thats what it looks like.
Old Jun 7, 2009 | 12:08 PM
Dayta's Avatar
im not saying anything about being ricer... i just want to see it, kind of hard to help with the info you gave
Old Jun 7, 2009 | 12:19 PM
freakta's Avatar
someone was talking crap about ricer hahaha. im on my phone right now and dont have a computer to get to. if you want i can send you the pics on your phone if you give me your number. but other than that. youll have to wait. im thinking the car needs some solid pipe. the 4ply couplers i have are just squishing together. as soon as i hit the gas they push back out i just dont like the vacuum sucked in parts
Old Jun 7, 2009 | 12:20 PM
Tennpenn83's Avatar
yeah, it's hard to picture how you mounted the tvs and where the ic piping would go...
Old Jun 7, 2009 | 12:22 PM
red_line_cobalt's Avatar
i need to see this
Old Jun 7, 2009 | 12:24 PM
slowswap's Avatar
Silicone couplers should always be straight section no longer then 3". I bet you're using non reinforced couplers that probably do 90 degree bends. And why are you using an air to air? It's a lot more inefficient then a water to air.
Old Jun 7, 2009 | 12:31 PM
WSFrazier's Avatar
Are you still using the stock liquid to air as well?
Old Jun 7, 2009 | 12:43 PM
freakta's Avatar
yes the couples are 90 degree and im not sure they are reinforced or not. they are 4ply so i figured it would be ok
air to air is going to be fine. i was looking for flow not so much cooling. the tvs doesnt make as much heat and ive got enough meth to keep things in check.
the tvs is in stock position. pipes come out the bottom and go to the front then come back and into the engine
Old Jun 7, 2009 | 12:49 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Well, a lot of people are gonna wanna see pictures. This has been a heavily discussed subject on this site... you might as well take pics now and post them up.
As far as the couplers go... like others have said... you need some reinforced ones.
Old Jun 7, 2009 | 01:10 PM
damien's Avatar
You can text me pics, PM me for my number. Can host them here after if you want.
Old Jun 7, 2009 | 01:13 PM
slowswap's Avatar
If all you cared about was flow, why would you add all the extra piping? That's killing flow. So you've killed flow and sacrificed cooling. Where is the upside to what you've done?
Old Jun 7, 2009 | 02:45 PM
Maxim_X's Avatar
Your pulling VAC as you know because all of those couplers are mounted after the TB. Normal setups will never see vac there because the TB is after them. You going to need to run metal bends and you can connect them with couplers as long as they are butted together. That should keep them from squishing.
Or you could try to set the TB up after the intercooler.
Old Jun 7, 2009 | 02:46 PM
freakta's Avatar
sent some pics should be posted soon
Old Jun 7, 2009 | 02:53 PM
damien's Avatar
Wow, awesome stuff.
Pics coming soon
Old Jun 7, 2009 | 02:55 PM
ItalianJoe1's Avatar
Agreed. You will need hard pipes for almost everything to hold the vacuum, silicone will flex too much and collapse under strong vac.
Old Jun 7, 2009 | 02:56 PM
Mattman6's Avatar
click
Old Jun 7, 2009 | 03:00 PM
damien's Avatar
TVS in stock position
Front mount
Side pipes
Top down looking at piping
Pretty neat set up.
Old Jun 7, 2009 | 04:00 PM
freakta's Avatar
ya its gonna work pretty well. just gotta get some nice solid pipe
Old Jun 7, 2009 | 07:16 PM
HunterKiller89's Avatar
if he managed to get rid of the stock intake manifold, he would be loved by soooo many members. That's the big point in his setup. after you ditch the stock IM, you can cool the charge however you like, be it air-air or water-air (without laminovas!)
Looks like the OP cut the bottom half of his IM off and attached a charge pipe to the remains.
Old Jun 7, 2009 | 09:20 PM
freakta's Avatar
you got the idea
Old Jun 7, 2009 | 09:30 PM
slowswap's Avatar
I bet his numbers will be lower then anyone elses with the same setup with the stock manifold.
Old Jun 7, 2009 | 09:37 PM
Doubtful. I'm actually quite interested in the results here, could be really impressive
