lsj cam options
lsj cam options
so I really want to cam my lsj. so far people mentioned grinding the stock cams and going to solid roller to make up for the loss of lift. I also saw blank cams for the ecotec not sure if they're 2.2 but I know the cps is different or something along those lines. basically I just want some decently lumpy aftermarket cams already made. anyone got any input?
https://www.cobaltss.net/forums/advanced-performance-modifications-130/new-blower-option-magnuson-tvs-1900-372hp-171438/ scroll down a bit they give the grind #s they used from comp cams
https://www.cobaltss.net/forums/showthread.php?t=171438 scroll down a bit they give the grind #s they used from comp cams
False
True
Go to advantaged search, enter "cams" in the search box, choose the drop down box for "Search Titles only" and then choose "2.0 LSJ Tech" from the category list. You will find more threads then you know what to do with.
https://www.cobaltss.net/forums/sear...archid=6991627
True
"Sorry - no matches. Please try some different terms."
Don't worry. I've failed many times before too.
Area comes through again. Thank you very much good sir.
I e-mailed comp cams about this. I also attached the cam specs straight from the article. Comp cams looked at the e-mial and replied "the intake lift is larger than the exhaust lift on all of our cams." Clearly hot rod mag specs dont concur. Everybody tells me comp cams wont work w/ the lsj b/c they dont have the hex engraving for the cam sensor, yet comp cams says it will be fine just the way they make it. So I ask...
