lsj cam options
Old Jun 4, 2009 | 04:52 AM
ff_drift_lol's Avatar
lsj cam options
so I really want to cam my lsj. so far people mentioned grinding the stock cams and going to solid roller to make up for the loss of lift. I also saw blank cams for the ecotec not sure if they're 2.2 but I know the cps is different or something along those lines. basically I just want some decently lumpy aftermarket cams already made. anyone got any input?
Old Jun 4, 2009 | 08:46 AM
StreetDreamz's Avatar
Call Crower. They'll do a set of any spec you like for $400 with cores included even.
Old Jun 4, 2009 | 04:40 PM
Blown 4-banger's Avatar
This same thread has been posted in the normal 2.0L section 100s of times. This thread doesn't belong here.
Old Jun 5, 2009 | 03:01 PM
oh my bad guys. the search thing kinda sucks or I just don't know how to use it. thank you for the info though
Old Jun 5, 2009 | 03:07 PM
ssyellow's Avatar
no the search thing really just sucks sometimes lol I have tried with that damn thing soooo many times.
Old Jun 6, 2009 | 08:58 AM
chevysssc's Avatar
https://www.cobaltss.net/forums/advanced-performance-modifications-130/new-blower-option-magnuson-tvs-1900-372hp-171438/ scroll down a bit they give the grind #s they used from comp cams
Old Jun 7, 2009 | 01:34 PM
Originally Posted by chevysssc
https://www.cobaltss.net/forums/showthread.php?t=171438 scroll down a bit they give the grind #s they used from comp cams
sweet thanks a lot!
Old Jun 12, 2009 | 05:27 PM
chevysssc's Avatar
read the whole thing first i think they said use a vacuum pump for your brakes with this grind
Old Jun 14, 2009 | 01:05 PM
yeah I've been through this with bigger engines. thanks for the info though guys I've been trying to find this stuff for months.
Old Jun 14, 2009 | 02:35 PM
ebristol's Avatar
False
True
Go to advantaged search, enter "cams" in the search box, choose the drop down box for "Search Titles only" and then choose "2.0 LSJ Tech" from the category list. You will find more threads then you know what to do with.
https://www.cobaltss.net/forums/sear...archid=6991627
Old Jun 19, 2009 | 09:41 PM
domin8_gt's Avatar
Have you tried clicking on your own link? You fail.
"Sorry - no matches. Please try some different terms."
Old Jun 21, 2009 | 10:53 PM
ebristol's Avatar
I guess it does not hold on the the search results for ever. My bad.
Old Jun 21, 2009 | 11:05 PM
Area47's Avatar
Rent me! per hour
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/cam-comparison-125002/
Old Jun 22, 2009 | 01:14 AM
domin8_gt's Avatar
Don't worry. I've failed many times before too.
Area comes through again. Thank you very much good sir.
Old Jun 22, 2009 | 04:35 AM
what about grinding down the stockers and using fatter lifters?
Old Aug 12, 2009 | 07:06 PM
harryresh's Avatar
I e-mailed comp cams about this. I also attached the cam specs straight from the article. Comp cams looked at the e-mial and replied "the intake lift is larger than the exhaust lift on all of our cams." Clearly hot rod mag specs dont concur. Everybody tells me comp cams wont work w/ the lsj b/c they dont have the hex engraving for the cam sensor, yet comp cams says it will be fine just the way they make it. So I ask...
Old Aug 12, 2009 | 07:08 PM
06blackg85ss's Avatar
should have bought mine
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
