Lsj + mp90 supercharger
Old 12-06-2010, 03:19 PM
  #276
redline4's Avatar
how does the GEN V m90 compare to the mp90? or is it pretty much the same in terms to the gen 3?
Old 12-06-2010, 11:45 PM
  #277
100% METH's Avatar
No idea
Pull a chart on the gen V m90 and compare
just got this done today... weld doesnt look pretty, but that won't matter since it's under the car anyway...
Old 12-06-2010, 11:49 PM
  #278
InfraRedline's Avatar
Lookin good steve-o
Old 12-06-2010, 11:51 PM
  #279
100% METH's Avatar
sank you kind sir
Got my 10gph nozzle today as well
All that's left is that I/O PORT and I can go make the tune.
Old 12-06-2010, 11:56 PM
  #280
You get parts so much faster than I do lol, ND sucks!
Old 12-06-2010, 11:58 PM
  #281
100% METH's Avatar
whiner!
you should sign onto AY AUI EM
Old 12-07-2010, 11:22 AM
  #282
Rattlesnake Race Shop
USMCFieldMP's Avatar
Is that your NAWZ? Spraying it into the Exhaust to make your exhaust flow faster... and shoot metallic green flames?
Old 12-07-2010, 12:18 PM
  #283
383_Stroker's Avatar
crank case vented to exhaust.... whats the reason you're going this route? (legit question.. not sarcasm )
Old 12-07-2010, 12:25 PM
  #284
mrbelvedere's Avatar
id say becase it will pull more crank case vaccum under accelaration
Old 12-07-2010, 12:27 PM
  #285
I know.
I had considered that at one time... but I think a proper pump set-up putting the Crankcase into vacuum would do much better.
Did you actually change the port on the back of the valve cover? Or leave it stock? Changing that port is the start of successful crankcase ventilation.
Old 12-07-2010, 12:32 PM
  #286
when i redo mine im blocking the port in the head off were the lim bolts on a pump setup would be a good way to go but it isent very cost effective
Old 12-07-2010, 12:37 PM
  #287
chevysssc's Avatar
how did i miss this
Old 12-07-2010, 12:41 PM
  #288
I understand how/why it works.. i just want to know why his set-up needed it
Old 12-07-2010, 12:58 PM
  #289
I think I seperated those sentances correctly.
Do you mean the Port for the PCV Valve that's in the stock Intake Mani? I've got mine blocked off now. Threaded it, then had an Allen Head plug put in.
And a pump set-up can be cost effective, but done properly, it probably won't be.
I've got the SAI pump off of my VR6 lying around. It should make a good start pump. Put a catch can of sorts in-between it and the -10an fitting that'll be on my valve cover... then rig a Hobbs Switch to engage the pump at 10psi. Should work out quite well, I think. We'll see. One of the better solutions, imo. Pulling 5-10in/hg of vacuum in the crankcase should benefit the engine quite well.
Old 12-07-2010, 01:59 PM
  #290
100% METH's Avatar
I think you guys got the idea
Old 12-07-2010, 03:03 PM
  #291
Answer???
Old 12-07-2010, 03:29 PM
  #292
we used a smog pump as a vaccum on are 70 duster it worked quite well after we figured the pully size but untill we did we were starving the engine of oil one thing we noticed was the rings ability to seal alot better once things were figured out
Old 12-07-2010, 04:19 PM
  #293
100% METH's Avatar
no
stock fitting
Old 12-07-2010, 04:40 PM
  #294
I've got the SAI off of a VR6 lying around. I might rig something up this winter. Should be fairly simple to make. Placement is where I'll probably have trouble.
Originally Posted by 100% METH
no
stock fitting
That's the key problem that needs to be eliminated. Make all the outside provisions you want... that fitting is still too small. Needs at least a -10an fitting put on.
Old 12-07-2010, 07:20 PM
  #295
just dont pull to much vaccum
No idea
the header collector would have been a much better place to put your fitting
Old 12-07-2010, 07:22 PM
  #296
HunterKiller89's Avatar
he did it more to keep oil out of the intake than to actually relieve anything in the PCV system iirc
Old 12-07-2010, 08:24 PM
  #297
100% METH's Avatar
I'm aware, but that's not happening unfortunately.
No room & it takes about 2 hours to take the header off
Old 12-07-2010, 08:28 PM
  #298
you wouldent have to remove the header to put it in the collector
Old 12-07-2010, 08:29 PM
  #299
unless he pluged the pcv passage it isent going to keep oil out of the intake
Old 12-07-2010, 08:41 PM
  #300
100% METH's Avatar
then there's the lack of room
front o2 and wideband are in the collector
Quick Reply: Lsj + mp90 supercharger
