Lsj + mp90 supercharger
Old 12-07-2010, 09:49 PM
  #301
HunterKiller89's Avatar
Originally Posted by mrbelvedere
unless he pluged the pcv passage it isent going to keep oil out of the intake
...yes it is?
what you smokin boy?
Old 12-07-2010, 10:15 PM
  #302
100% METH's Avatar
mis-judged the bung placement
need to bring it up 2 inches to clear the exhaust canal/heat shield
going back to the exhaust shop tomorrow... fml
Old 12-08-2010, 12:51 AM
  #303
mrbelvedere's Avatar
Originally Posted by HunterKiller89
...yes it is?
im not smoking a dam thing oil can be shoved back through the pcv port
Old 12-08-2010, 02:46 AM
  #304
100% METH's Avatar
@ Mrbelvedere
I'm welding in a -10an tmrw
Old 12-08-2010, 03:01 AM
  #305
which PCV port. the one on the intake? (which is closed off) or the one on the valve cover? (which leads to the crank case...) the path is just from crank case to exhaust with a check valve in between. I dont see any connection to the intake.
Old 12-08-2010, 03:03 AM
  #306
cmatthewb101's Avatar
Do we still not have dyno numbers?
Old 12-08-2010, 03:31 AM
  #307
100% METH's Avatar
unfortunately not
unusual set backs unfortunately occurred
hoping to get them cleared up by Thursday at the latest, so I can finish the tune and get it on the rollers by this Saturday.
Old 12-08-2010, 08:30 AM
  #308
the only way the pcv is closed off 100% is if you put a pipe plug in it that check ball setup iis garbage
Old 12-08-2010, 10:47 PM
  #309
100% METH's Avatar
you talking about the pcv plug in the center of the intake manifold flange?
Old 12-08-2010, 11:36 PM
  #310
yes in deed
Old 12-08-2010, 11:56 PM
  #311
again, where is there a connection to the intake?
Old 12-09-2010, 12:07 AM
  #312
100% METH's Avatar
yes in deed
good to know
ill make sure its plugged
Old 12-09-2010, 10:43 AM
  #313
that check valve does go bad oil will be pushed back through the hole and into the intake manifold
Old 12-09-2010, 11:10 PM
  #314
steve explained it to me. the 2.2 head doesnt have the IM to head port, so i forgot about its existence.
Old 12-10-2010, 01:38 PM
  #315
Rattlesnake Race Shop
USMCFieldMP's Avatar
just dont pull to much vaccum
Or else?
Old 12-10-2010, 02:19 PM
  #316
Or else?
you can or will inhibit the ability for oil to circulate through the engine and it will starv to death
Old 12-10-2010, 03:56 PM
  #317
i feel this isnt accurate. havent heard of anyhting suggesting vacuum pumps lead to oil starvation
Old 12-10-2010, 04:22 PM
  #318
100% METH's Avatar
We have a baffled valve cover
uploading pix n videos of pcv evac setup
Old 12-10-2010, 06:45 PM
  #319
100% METH's Avatar
Click picture to view video
suction
hooked up
excuse the mess... got a little RTV happy on a previous gasket
Old 12-10-2010, 06:51 PM
  #320
383_Stroker's Avatar
A LITTLE?!
Old 12-10-2010, 07:04 PM
  #321
100% METH's Avatar
haha..... ya :/
Old 12-10-2010, 08:21 PM
  #322
to much can
Old 12-10-2010, 11:52 PM
  #323
to much can
again, havent ever heard of this happening. Not saying it cant, but i dont know anyone with a vacuum pump who has had oil starvation issues. What exactly would they be starving? main/rod bearings?
Old 12-11-2010, 01:21 AM
  #324
well when we first used one hardly and i mean hardly anyone had done one we used a air pump and played with the pully size till we got it right and yes we did starve an engine of oil to much vaccum makes it hard for the pump to suck it up and it will force the oil to stay up high in the head
Old 12-11-2010, 05:19 AM
  #325
are you referring to the ecotec platform specifically? and it doesnt make it harder for the pump to suck it up. The pump is pulling from the pan from a submerged point. The oil would not resist flow at all.
Quick Reply: Lsj + mp90 supercharger
